Alex_Blackwood
Yes but you should also fit a 16 amp MCB as an incomer isolator. Boathook refers! If you use compact units you will be OK for fit. You may have to use a 2 module unit for the MCB. Compact units are available RS is one supplier but they are not cheap. You may be able to get units at reasonable prices by doing an online search, but be careful of cheap Chinese units. I am not certain from your picture of the existing box if it is a 4 or 5, possibly 6 way? I can see at least 2 blanking spacers to the right of the RCD.Okay so if I use the existing board and remove the rcd and fit-
16a rcbo for sockets
10a rcbo for water heater (1200w)
6a rcbo for battery charger
I can buy these three rcbos for £53 from Screwfix.
As a further note ref. the Garage unit in your previous post. I should add that the RCD used is the old AC type not TYPE A which should be used now. Another reason it is unsuitable!
