dom
Seen many a boat, even RIB's, in difficulty when the tide has dropped (even in Solent/Cowes), leaving lines tightened under the weight of the boat, because locking hitch has made it impossible to release from cleat. Not a nice sight, seeing boat hanging, awaiting cleat to part company with hull.
I and others have explained the advantages of a locking turn and why one should be grateful if it ever tightens. What have tidal ranges got to do with this?
I'm guessing you mean that a badly moored boat will see its mooring lines come under tension as the tide falls, which will in turn see the locking hitch tighten to the point of being impossible to open. If so, it follows that you believe an OXO would normally slip under such strain, for there is no other way the hitch could otherwise tighten.
Try again #73.
So that is what you meant! In which case I guess you have a point:
If you don't understand tides and find your rib/boat swinging from the pier wall...
...then you'll be glad you don't understand knots either!
Little wonder the owners of superyachts are skeptical of the YM qualification
