OK - you have the boat .. you later bought an item that far exceeded expectation ?
Fire99
11 Oct 2001
Bangor NI
I have found string has surpassed all my wildest expectations.
Need something to tie your shoes, no problem use string,
Need something to hold your hat on, no problem use string.
Need something to lash down your dingy, no problem use string.
Need something to keep your glasses on, no problem use string.
Need something to keelhaul troublesome crew, no problem use string.
Need something to repair a sail, no problem use string.
Need something to .........
There's a few more strings to your bow :D
Refueler
13 Sep 2008
Far away from hooray henrys
Mossies are not attracted to UV light in any form or way ... the only attraction there is if it gives of some 'heat' and you being close by exhaling CO2 .... and then its only odd Mossies that will go to it.
Its been done to death on so many forums as to the reality of Mossies ...
1. They have an incredible range of detection of CO2 .. exhaled by animals.
2. They also have heat sense that allies with #1- along with animal odour
3. Male Mossies have no interest in you or any animal
4. Female Mossies are the ones who bite - as they are seeking blood and the water contained within.
5. Synthetic Citronella is nowhere near as effective repellant as natural Citronella - but natural Citronella is expensive.
Basically - the Female Mossie detects the CO2 and then homes in on the source using both the CO2 and heat ....
The most effective Mossie 'killer' are the LPG units that produce CO2 and heat ... they have a collector with water ...
Mossies home in on the CO2 and heat .. get drawn into the collector. They are usually used to clear areas next to ponds and water channels and can literally clear a large area in a day or so ..
Refueler
13 Sep 2008
That reminder may have saved me a few quid - oly to spend it on Deet if we end up somewhere with mozzies.
Money has been wasted on UV and other stuff in the pursuit of Mossies - but a little bit of search online soon reveals the 'con' ...
UV and so on are great for 'Midges' general Flys, Moths etc. - but one of the best ? Kerosene lamps ... not the glass hurricane jobs ... but the open flame jobs you see fitted into bamboo poles ... ring of those around the BBQ area and they don't like it ... especially if you get the 'Citronella style' fuel ..
Daydream believer
6 Oct 2012
Southminster, essex
OK - just to jivvy things up ... the most useless items ??
I bought a pair of 'roller chart rules' one small - other large. I was a parallel ruler user - dab hand at walking a set across a chart ... but of course on a yacht - you don't have that massive chart bench. I saw a set of roller in a shop one day and thought - give em a try ...
example :
Bloody useless ! OK if boat is rock steady and no movement - but slightest twitch and rollers slip ... so back to two triangles and pair of dividers.
I was given one & have used it a couple of times when planning a route on the quick. However, I have one with rubber rollers that came from Cptn O M Watts 56 years ago & that is better. I cannot get on with parallel rullers but i do have a set of GPS position rulers & they are very handy if I have not got the Yeoman plugged in, or I am setting Yeoman plot points on a new chart.
I have 2 Douglas protractors. A 12 inch & a 6 inch & I am damned if I can use them. :cry:
zoidberg
12 Nov 2016
The Royal Air Force issued Douglas Protractors to all its navigators, back in the day. Like Wrist Watches, Navigators and Nav Bags.... pilots coveted them, but soon gave them back 'cos they didn't understand them/couldn't use them. Mostly because they mostly couldn't count to more than 20 - and that was with their shoes and socks off...
Daydream believer
6 Oct 2012
Southminster, essex
Perhaps a thread on how to use one might be fun.
Roberto
20 Jul 2001
Lorient/Paris
sybrancaleone.blogspot.com
Simplest device ever. That's what I was tsught to navigate with. And cheap!
Is this it? I've added the thin line it came without it, very quick for GPS coordinates, course or bearings/clearing bearings location. Part of the line goes through a thin ballpoint pen tube one can also draw segments of straight lines :)
Refueler
13 Sep 2008
The Douglas is an act on its own !!
My Father ex RAF had a whole bunch of them ... gave me one still with RAF Id number on it ... its somewhere amongst the boxes ..
