schilde
Is there an oil expert out there?
I fitted some clever valves so that I could flush my sea-water cooled inboard engine with fresh water. When I tested it I left the water running after the engine stopped, and filled the exhaust with water. I realised what I had done overnight but by the next morning the engine had water in a cylinder and in the oil.
I then did two oil changes to get the watery oil out of the engine, and I think the engine will be undamaged.
As I had only just finished a complete rebuild of the engine it and the oil were really clean, apart from the (fresh) water. I heated the oil up in a saucepan and boiled off the water. (carefully!) I heated it very gently to avoid burning the oil. It probably went just a little over 100 deg, maybe 110 or 120.
The question is, is this oil now as good as new? Surely oil must be designed for parts of an engine where higher temperatures will be encountered, so will it be damaged?
The oil is 10/30 and 10/40 4-stroke oil for marine petrol engines.
I know it is cheap to buy new oil but it is a shame to waste it and someone has to pay to dispose of it.
I now turn off the hose before stopping the engine!
Steve
Steve
