jfm
I think you're right. In addition to what you say:
1. These motors have standard flanges, so it's quite easy for a mechanic to fit a smaller motor if the original BCS motor failed.
2. The wire gauge: the incoming 12v +ve motor supply is 100% hidden in the shorter white corrugated tube, but you can bet it is a thick wire. (The black and red you can see on the right hand side are merely the supply to the solenoid coil). But the main 12v +ve to the motor is that OEM fitted red tail wire to the motor, and it's tiny. Perhaps 10 amps, so if this is a 12v boat that's 120 amps of motor. Belongs in a boy's train set. So tiny you don't even need a solenoid.
So, as well as everything you wrote, this also points to a conclusion that the motor is a retro fit and is too small. Worth checking Portofino, because if this is the cause of the defective steering you reported on YF a few months ago this would be a really nice fix/upgrade to your boat, and very easy to do.
Oh, and correct regarding Ackerman rudders - no boat driver could feel any effect at the speeds these boats do. So I don't hate Riva's decision here but I do prefer SL's preference for redundancy over Ackerman.
