Navico RT6500S
James
11 Sep 2001
Is this radio any good?
How does £50 or £60 sound second hand? I've been offered one.
Thanks for any advise.
<hr width=100% size=1>
Ivy
20 May 2003
Bournemouth, England
I presume it is a fixed VHF set?
I would sugest you get a DSC radio, you can buy one for less than £200 now. In a few years the old VHF won't be much good.
If you are stuck without a radio pick up a cheap hand held, these are always usefull when the Mate goes off in the dnghy.
dickh
8 Feb 2002
Suffolk
My friend had one on his last boat, worked OK. Your price of £50 to £60 is about right, but insist on seeing it work before parting with cash... Should be able to do if your near the coast
<hr width=100% size=1>dickh
I'd rather be sailing... :) /forums/images/icons/smile.gif
Mudhook
16 Oct 2001
South Norfolk
Make sure it works and buy it. They are a very good set and will last for years. If you are short of money, a decent second-hand fixed set to get you by is a far better bet than a cheapo DSC, and 1+1 DCS/Controller units are a waste of time, money and space in my view. And a hand-held as your boat's main radio seems unwise. I was able to replace my defunct Navico RT6500S with an unused, identical set, still in its box, for £100 recently, sourced through the web, so your £60 is about right.
If you have the (somewhat obscure) round power feed plug and don't have the male part to plug into the radio, you can get 'em from Radio Shack. Later models had a flat nylon plug.
best of luck.
Mudhook.
James
11 Sep 2001
THANKS also Swiftech M198 handheld
Is the swiftech M198 any good. Approx £50. Only worry is that the battery pack is a unit i.e. if duff - will need fiddling about to install new batts.
