SimonNZ
We want to replace a old halyard; it's a stretchy DIY store rope, not sure how it got there.
We have another good quality halyard in place. Both run internally and end in shackles; the good halyard runs back to the cockpit, the stretchy one to a cleat on the mast. I flew the drone up to get a closer look at the masthead mainly to check the block size to see how easy it would be replace it, by stitching a replacement end to end. Looks good.
The good halyard exits downward via sheave, the lower white rope in the pictures. The one for replacement exits upward to a block, black in the pictures. My questions are about the mounting and block for the black rope in the picture:
What is the name of the V shaped metal hanger for the block?
Does the design and position suggest this is designed for the spinnaker? It is above and outside the top of the jib furler.
Does the metal hanger look like it needs some attention? It appears to be deforming the masthead to which it's fitted. We not actually intending to use the spinnaker before the standing rigging is replaced anyway, so we'd get this looked while the mast is down.
Thanks for your expertise!
