vas
Great stuff Vas. The angle/overlap joint is called a scarf joint btw, or scarfing is the verb. It adds a nice benefit as you say in making the finsihed surface less prone to cracking by removing a "notch" ie a point or crease with different stiffness from the rest.
John, I owe you another one...
by giving me the right name for this joint, I managed to search successfully on the web, found ways of doing it, and how the pros do it. I'm not a pro, but with the help of George should be able to prepare the area for the first patch. Organised so tomorrow we'll have an electric plane and a belt sander for finishing off...
Preparing for the patches that will follow, I had to remove the flooring on the second cabin. Spent half an hour trying to figure out how to do it without destroying the ply and underlying frame, and eventually decided to scrap the lot. Ply was already affected (and of lower quality to the one I've seen around MiToS), frame was plain white timber.
Further I noticed that after the stbrd side bed of this cabin (i.e. towards the corridor) there's a nice flat bottomed area that I could install my black water tank. OK, I can hear you saying various things, but I'll try that spot as it's just offset from the keel, it's easily accessible, close to the two heads (just towards the bow of this cabin) and plenty of space: Max size of tank I could fit is 1.9mX0.45mX0.50m, that's massive! but could easily fit a 200-250lt tank there.
apologies for the crappy photos, today wasn't a good day for some reason. Note the doubled up frames, the inner patches and the whole mess around this large patch that is about to be replaced:
And a v. interesting discovery! When I was cleaning and generally walking above at the galley (OK walking maybe an exaggeration as you can just about make 1.5 steps in there...) I noticed that part of the floor was feeling a bit loose. Well, found out why. There's a secret hatch sawed in the floor ply and underlying frames. I really don't want to think what the PO has used it for
So, all settled for tomorrow's operation
Ref the davits, the bolts will for sure be exposed if you remove the transom lining. But surely you want to keep the davits till you've done the aft deck, becuase they form a nice frame for your canvas tent?
Anyway, thanks for the pics. I'm enjoying following the story
f/b goes far aft almost reaching the transom, so no need of the davits to support my temp cover. Actually it's creating a problem as I could do the job with a 3m high cover and now I need something around 5m plus the stress points at the two peaks. So got to go soon, just checking my options re passerelle before removing them
ah, +1 on rafiki's request for a glossary of terms! Would be v.nice and help me improve my terminology and sound like a pro
cheers
V.
