vas
MiToS re-built/fit- Versilcraft Mystere43
Hello all,
boat was lifted out on Friday and I have 6 months to do some of the work I have planned for. Doubt I'll manage all of it, but time will tell...
[thread edited in 2018 to add an index which gives me the opportunity to note that my estimate wasn't really spot on... Took four years to get MiToS seaworthy and back in the water, another three in the water and there are still some finishing touches to be made]
Anyway, first with the lift out pics done the old fashioned way with a tractor thingy, massive trailer (good for 50ton boats apparently) and extra support from a winch located some 80m away in a shed (a pulley also involved as it's on a 90degree angle to the exit path...). The lift out process had the whole family of the boatyard involved, namely dad driving the tractor, 14yo son checking in the water that the boat settled properly on the trailor (and then moved away safely before lifting), wife connecting and checking the wire to the winch and pulley and grandma (!) operating the winch in the shed. I was in the craft so couldn't film the process I promise I'll get someone to do a decent documentary in June
and cheking the supports before moving to store.
Have to admit she's now in a fine spot by the water with fine views of the port and city of Volos, some 4km from home and 3km from my office
Original rough to-do list replaced by an index to the thread as it's now too long to be scrollable and searchable by any other means. Apologies as indexing is rough at the edges since I tend to work on many things at the same time creating a chaotic work progress report on here. Not much I can do, so go for the milestones and scroll through the neighbouring pages, you will get there at the end!
Taking things apart:
Superstructure work and Repairs:
Hull work:
Design:
Finishing:
Interior work:
Various jobs:
Milestones:
A rough plan of how I'm planning the refit (more on the design links above):
Spend 2 hours on Sunday dismantling the main cabin. Managed half of it down to bare structure and plywood.
original condition:
removing bits:
down to the nasty detail that caused a lot of damage and some rotten pieces of plywood on port side (already replaced but not with great craftsmanship, so may have to remove and replace again, we shall see..)
more to come over the following weeks/months (hopefully not years though!)
and finally a pic of two fine italian ladies:
cheers
Vassilis
Hello all,
- bow cabin 15, 39-48, 154-157
- heads 49-54
- port cabin 176, 481
- electrics cleanup 72, 97-112
- transom clearup 634, 652
- paintstripping 145, 183-184, 207-224, 232-277
- Deck replacing 278-370
- Toerail 880-, 905-925
- Superstructure patches 370-380
- salon deck replacement 652-
- aftdeck replacement 723-729, 762-787
- Swim Platform 1186-
Hull work:
Design:
- Lower helm 113-118, 128-137, 1107-, 1348-
- Upper helm 92-96, 390-436, 1330, 1451
- Cabin layout 118, 133
- External colour tests 391-400, 436-
- Hard top 1333-, 1402-, 1431- (installation)
Finishing:
Interior work:
- Redesign construction 504- , 939-, 1007
- Upholstery 829
- Finishing cabins 1349-, 1410-
- Salon material and flooring 1365
Various jobs:
- Black water tank/pump/setup 138-158, 175-182, 225-228
- aftdeck seating 790-799
- bow windlass, switches, anchorlocker layout 801-828
- anchor boy 1391
- Teak decking 946-
- Sliding doors 955-
- Chart table / galley 1104
- Watermaker 1186
- Heat exhangers 1189
- Mooring gear 1348
- Exhaust elbows 667
- f/b and windscreen cover 1387
- automation 1414
- SS MiToS lettering 1352
- f/b seating support 1448
Milestones:
- First year anniversary on the hard 723
- Second year anniversary on the hard 706
- Third year anniversary on the hard 1063
- Relaunch 1309
- Floating again 1269,
1248
original condition:
removing bits:
cheers
Vassilis
