lpdsn
My anchor locker is more or less a three sided inverted pyramid with the lowest point and the drains just an inch or two above the waterline. In any seas (and around here when there's a forecast without a six in it you assume the Met office have made a mistake) my anchor chain gets a good salt water rinse even in the locker.
The bit of the old chain that was at the bottom of the locker had corroded so badly that it took a fair bit of ingenuity and brute force with a block and tackle and a line led back to the winch to get it out and it was just a mass of rust.
I don't want the same to happen to the new chain and have been thinking how to avoid this. By far the easiest of the ideas to implement is to throw a couple of half-spent anodes into the anchor locker then put the anchor chain in on top. I should have enough spare to replace them after each time I lift out.
Any thoughts on why this might not work?
