A close shave
Greenheart
29 Dec 2010
The whole business of confined spaces makes me windy. I only had to lie on the foredeck and reach far forward into the 24" deep anchor locker to reinforce (in fact, rebuild) the out-of-sight forestay tang, but it was fairly horrible.
...a high pressure hose would not have helped. I "just" needed to clear out lots of heavy bits and pieces (stones, shells, washers, pieces of monel wire and cable ties)...
I think I would have tried a lot of duct-tape, sticky-side-out, on the business end of a boathook. If there's really a lot of muck down there, a scoop on the end of the stick could be contrived that would pick up handfuls of damp grit, gravel and oddments.
Anything beats risking getting wedged.
Supertramp
18 Jul 2020
Halifax
I have a "litterpicker" which is magnetic and strong enough to pick up a spanner. It is invaluable for retrieving things like bolts or screws from under the engine or bilge and is useful for wiping up drips and spills during engine servicing.
As with others here I have got wedged into various lockers and hidden areas but fortunately not for long.
thinwater
12 Dec 2013
Deale, MD, USA
sail-delmarva.blogspot.com
A life jacket, at anchor? In fact, It's common to remove belts and other snag points when riggling into tight places. But yes, some jobs require a watcher.
The problem can be re-boarding. ISO and ABYC regulation require a ladder that can be deployed from the water, without help, with at least 2-feet under the water. If you do not have such a ladder, now you know why you need one. If you can't easily swim to a transom ladder and reboard, swimming classes are in order. I think most US sailors grew up swimming in the surf or surfing (warmer water), so we have a different relationship with swimming in waves.
