eddystone
My Smartgauge (just changed both fuses) is showing error code 03 which means voltage is too high. I thought maybe the PWM controller has failed and 2 x 20 solar panels (probably not 2 x 20 after 10 years) overcharging the batteries, although lights on controller seem normal. However, with error code 03 you can still press buttons and get a voltage. Showed domestic pair at 15.5v ish and engine at over 14.5v (engine battery not connected to solar). Checked batteries - no evidence of heating up. Checked voltage with multimeter - domestic 13.7ish, engine 12.8, which is what I would expect with solar trickle charging domestic, no load and recent extended engine run charging on 1+2
Faulty Smartgauge?
Faulty Smartgauge?
