Masthead Vertigo
tome
28 Mar 2002
kprick
www.google.co.uk
Feeling pretty pleased with myself after going up the mast yesterday and fixing all the minor problems. I hate working aloft!
I spent a good hour getting together all the gear and tools I would need, then slackened off the backstay to take the tension off the forestay. It took me 10 minutes to get up 50ft above WL to the masthead using the Topclimber. Once there I hooked a safety line over the masthead and took a breather.
First job was to properly fit the split pin on the toggle holding the forestay. This was barely through the pin and not splayed - hanging on by a thread. I'd practiced on a lower toggle before going aloft, so had the mole grips set up ready. Even so, it took a good 15 minutes to do this simple task and I managed to break a pair of long nosed pliers in the process.
Next job was to replace the spinnaker block. The one fitted was on a snap-shackle, which is dangerous aloft. It wasn't articulating properly and was on a long shackle onto the masthead U bolt. This shackle had begun to wear badly, and had started to damage the headbox. I'd already dropped the halyard from on deck. Sods law came into play and the shackle proved a right b*****d to remove. This took another 20 minutes. I eventually fitted the new block (I was terrified of dropping the shackle pin) and moused it with monel wire. I threaded a 4mm mouse through the new block and dropped both ends down to the deck.
Then it was bulb replacement time - this time I didn't leave the bulbs on the chart table! I'd decided to replace the tricolour bulb also, so went to the Pumpkin chandlery in our marina to get a spare. They were out of 12V 25W bulbs but took one out of a new light for me - they really are helpful in the Northney branch. When I removed the lense I saw that there was no bulb fitted to the anchor light, so I applied some vaseline and put in the new bulb. Took out the tricolour bulb and discovered it was 10W! Somebody had replaced a blown tricolour with the anchor light bulb. More vaseline, and back on with the lense.
All that remained was to measure the mast height. I have a set of plans for my boat from Holman & Pye but there was some suggestion that the later boats had a taller rig and I wanted to check this. I taped one end of a 50m surveyors tape at the boom gooseneck and took the rest aloft. I measured 41ft 3in which is exactly what the plans say.
By now it was getting a little breezy and I was worried about my messenger line. I'd been aloft for about an hour and a quarter and my feet were beginning to ache in the Topclimber webbing straps. As I descended I saw that the messenger line was a little short and blowing around just above boom height, so I shot down as quickly as I could. Fate was smiling for once, and both ends came to hand. Couple of minutes later I'd re-run the spinnaker halyard.
I took some digital pics whilst aloft for future reference, and was feeling pretty chuffed with myself. All done, and ready for a serious lads sail this coming weekend (Alderney if there's any wind). Bloody glad to hit terra firma though!
Gordonmc
19 Sep 2001
Loch Riddon for Summer
Well done. Must be some sense of satisfaction.
I hadn't been up a mast in decades when last Autumn a pontoon neighbour showed off his mast ladder. We hauled it to the top on the mainsail halyard and off I went. Got as far as the spreaders when sanity kicked in. Sod this for a game of soldiers.
I make doubly sure all the jobs are done when the mast is stepped.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
How are your leg muscles today?
After long sessions up the mast I find I have muscles where I thought there were none, from trying to hold myself steady. I read, and have found myself, that wearing wellies when up the mast gives better grip for the legs. Also protects somewhat from bumps and scrapes.
tome
28 Mar 2002
kprick
www.google.co.uk
Agree with you - all the jobs I did would have been very easy if the mast was unstepped. First time up I was trembling at the spreaders and almost gave up, but somehow kept going and found it didn't get any worse. When I reached the top I took time to do a thorough survey and take some pics. The pics were a great help in planning the subsequent repairs.
It was obvious that I'd have to go again (not least because I'd left the bulb behind) and it was hanging over me, especially the split pin which could have failed and cost us the rig.
This last was my third trip and I was getting more confident in the gear. My wife will tell you that I suffer from vertigo and reckons I turned green at the top of the Eifell Tower. Meantime, she was hanging over the edge taking photos! I couldn't do it as I'm convinced that my centre of gravity is at head height and I'd topple over.
tome
28 Mar 2002
kprick
www.google.co.uk
Re: How are your leg muscles today?
Bloody sore, thanks!
With the Topclimber, your feet are in a pair of webbing straps so I don't know if wellies would help. It does have the advantage that when you stand up you are above mast-height, and you can sit down in the seat whenever you need a rest. Even so, it was getting uncomfortable - probably because the safety harness I wore as additional protection didn't allow me to fully sit down. A longer safety line on the harness might help in future.
When the mast next comes down I'll be fitting a spare U bolt to the headbox so I can clip my harness on.
Jools_of_Top_Cat
16 Dec 2002
apparently men suffer far more from vertigo than women, and it gets worse as you get older. I am terrible, I did not realise how bad until my sister was temporarily living on the 14th floor about 6 years ago. I wandered onto the balcony and peered over the edge, my stomach turned over, all the straight walls looked curved, I stayed there to try and get over it, but even after about 10 mins I was still not comfortable about it.
I can go up a ladder to my 2 storey gutter on the house, but don't enjoy 2 seconds of it, as a kid we used to shimmy up the drain pipe of a tall 4 storey school and sit in the sun on the roof, I loved it then.
Guess I am turning into a whimp,
<hr width=100% size=1><font color=blue> Julian </font color=blue>
<A target="_blank" HREF=http://www.topcatsail.co.uk>Homepage</A>
tome
28 Mar 2002
kprick
www.google.co.uk
Julian
Interesting - I used to do rock climbing as a youngster and loved it! I will certainly go up the mast if I need to, but can't pretend to enjoy it. It certainly gets a little easier each time you do it.
Read on the Topclimber site that one senior gentleman sometimes went up just to 'enjoy the sunset' but can't see me getting to that stage.
Regards
tom
Neal
6 Oct 2001
Devon
One of the real joys of a gaffer..
is hauling yourself aloft on a warm spring day, using the 4:1 throat halyard, then working your way down slowly, applying varnish to the mast with bare hands. Messy, but so staisfying in a very primal way.
We've also got a cam cleated step climber thing - Can't remember its trade name, but it works a treat. It means the Mrs doesn't have to haul me aloft - she just takes a turn as I walk up. Works really well, and we use it a lot on bermudan rigged boats.
I love going aloft. love the views.
jimi
19 Dec 2001
St Neots
Vertigo
I used to do a lot of rockclimbing and often enjoyed the sense of exposure while climbing or hanging off a belay. But I hated standing at the top of a cliff, tall building balcony, harbour. For some reason that terrified me!
Spyro
18 Jan 2003
Clyde
Topclimber
Bet you wish you got a pound for every time you mention "topclimber" on this forum
or perhaps you do LOL
no offence meant
tome
28 Mar 2002
kprick
www.google.co.uk
Re: Topclimber
Spyro
Agree I seem to be hammering on about it rather a lot, no connection whatsoever with supplier. It just happens that I recently bought it and then saw Emma Richards use one on telly, then responded to a thread etc.
Aplologies if I'm rattling on too much, but I do think it's good and have never been up the mast unaided before.
Regards
Tom
Isn\'t a brush easier?
but squelching around in the varnish must provide sensual stimulation, yes?
Joking aside, Vertigo is my only real phobia (well apart from certain charter companies being alongside!). Rough seas & being thrown about in a rally car have little effect on me.
I once sailed all the way to St Malo to change the bulb in the masthead lamp by entering the Rance barrage lock early, going up onto the wall and pulling the masthead over with a strop. That was only a 23footer though. On the next boat a 30ft Hunter I used to bully son #1 aloft - but he is too worldly wise now and it would cost me too much in bribes!
Our current Bavaria 42 is on management in Greece so when the wind sender froze last month a yard hand was sent aloft to replace it.
God knows what I'll do if anything goes wrong up there when we take her out of service! I might consider putting her up for sale if the masthead light went out.
Ad. could read:-
"For Sale Bavaria 42, well maintained, all perfect except blown 95p bulb at masthead."
Steve Cronin
qsiv
30 Sep 2002
Channel Islands
That explains a lot. Last year I went to the top - fitted a second spi block to the crane, replaced a U bolt etc - but I have to say the extra two feet to dismantle the masthead tricolour defeated me. The wind was kicking in and I realised I didnt actually know how to take the lantern off - so I wimped out and came back down to the deck, in order to research just exactly how the light comes apart in the security of a chandler - then I'll get myself winched back up and finish the job.
I dont know whether it was just the height (85') or whether it was having my chest at masthead level for the light that unsettled me. I suspect it was the latter as I felt hugely more exposed once my head poked over the masthead. How the singlehanders replace their wind instruments at sea, God only knows! Just getting a 2m carbon wand up the rig without breaking it is quite some achievement.
vyv_cox
coxeng.co.uk
Mastclimb
is its name. That's what I use. Hell of a lot of money for 18 inches of 1 inch square tubing, a foot of 1/4 inch rod and a camcleat, but there we are.
I suspect that if you put a camcleat on the bosun's chair, together with the Mastclimb, you would have something very like a Topclimber.
I don't use the Mastclimb in the way they suggest, on a single line with a block at the top. I always set up a line for the Mastclimb and put the bosun's chair on another halyard. Adds a little safety factor but also increases the lift gained for each leg push.
