vas
Paul, I'm a bit confused on how your hybrid vs what SeaChange in #4 describes compare.My recent Lithium installation is hybrid. I have 2 x 60a @24v alternators (twin engine mobo) and don't feel inclined to spend close to £200 for a Victron DC-DC charger with just a 17a output. Also not inclined to spend the excessive cost of high output alternators.
So far, it's looking good, not seen the alternators putting out more than 30a each. Just connected the Victron system to the N2K network, so i'll be able to monitor everything from the flybridge next time we're out.
I do run a what I'd call full hybrid system in that MPPT, Multi-II and 60A port engine alternator (via a Stirling regulator) all go to a 4XTrojan T105RE bank which runs permanently linked to a 8 cell 304Ah EVE cell LiFePO4 bank. LiFePO4 has a 500A BlueSea relay disconnect (wired to the bms) and a T-class fuse.
diyBMS (its a brand of open source bms, with 1A passive ballance per cell, google it) is not a solidstate job like the ones you all seem to be using, so I can go 2C+ charge or discharge or whatever I want on the bank without issues as loads go straight to the battery terminals. Realistically I typically go 0.5C-0.8C if I run watermaker and a few other loads in the evening (which I avoid but it's beyond the point) so I'm not really taking full advantage of not having a solid state system, which I guess would be more interesting to the 12V wired boats.
So having both banks linked means that if the bms is not happy (battery fully charged and alternator still pumping 20-30A due to extensive motoring) or battery is lower than 15%SoC, then bms instructs the BlueSea to take the LiFePO4 bank off line leaving the T105 to take care of the situation. No spikes and burning the alternator this way.
V.
