JPK 39FC
doris
19 Jun 2001
London
Agree, but solar is very worthwhile, and works very effectively in the UK. Plus for a boat like that, semi flex panels are very light weight as well as cost effective. Doubt anybody has ever regretted adding solar panels.
As soon as the panels are made to be walked on the efficiency plummets and I don’t want a big goal post style arch on the stern for decent panels.
Maybe flexi roll outs may work in the future.
Numbers
19 Mar 2024
Will you be having a battery up forward somewhere for your Windlass and Thruster?
I realise there would be voltage drop over a long run, but adding another battery does add extra complexity/connections ... could a long run of thicker cable be lighter than a second battery?
Is it set that it's all 12 volts ... or is there any option for 24 volts? (to reduce the thickness of any cable runs)
dunedin
3 Feb 2004
Where do you mount and store them ?
I would have put on the coach roof but ours is teak so two on the sprayhood - which stays up for us, as have windscreen below.
One roving panel which gets moved around. Been seriously abused for 6-7 years with no detriment to function.
Abandoned a rigid panel which was too much hassle and now lives in garage.
John_Silver
19 Mar 2004
St Mary's Island
allatseawithstargazer.blogspot.com
Stargazer has an all roving set up. Using these SunWare TX panels. Basically 2 of their semi rigids mounted on a stout ‘canvas’ backing. So that they fold like a book. A pair stow well in the aft cabin. (Which is a much smaller affair than that on a JPK 39FC).
I had cringles added to each corner (for lashings) and loops added to the backs. The loops allow me to insert aluminium tubes. Which prevent the panels folding; and allow me to cantilever them off the cabin top, to avoid shadow.
At anchor, one usually lives just ahead of the mast. Off to one side, to avoid shadow from mast / forestay. The other is lashed to the cabin top grab rails, on whichever is the sunny side.
This set up is ‘tacked’ at turn of tide.
All channeled through Victron MPPT magic boxes.
During the ‘staycation’ year. When no ports would have us, we went 73 days, of a UK summer, with batteries kept fully charged, on this set up.Running fridge, lights, instruments etc at will.
The smaller SunWare semi rigid, which is visible, if you zoom in on my avatar picture (leaning against cabin side, up forward), has travelled from boat to boat. Since the late 90’s. Living in the aft cabin, unless at anchor. It’s holding up well.
doris
19 Jun 2001
London
Ta for that John, v helpful 👍👍
Chiara’s slave
14 Apr 2022
Western Solent
We have an ‘extra’ panel on the sprayhood, we had eyes put on the hood for this purpose. It’s meant to be temporary but we only remove it for racing and cleaning. The other panels are behind the anchor locker, and on the coachroof in front of the mast. The 3 together are 250w which seems to serve our needs in uk, even though our outboard charging is pathetic. ThevJPK will have a stonking alternator by comparison, so a folding setup might well be almost all you need, plus maybe a permanent 80-100w panel to make sure you’re 100% ready to start the engine always.
Numbers
19 Mar 2024
Doris (and others)
pardon me for being newbie ... Doris, you mentioned a Feather Stream propeller ... I've never heard of that brand ... but I see Gori folding props on YouTube everywhere.
would love to get some differing points of view of Featherstream versus Gori?
Can anyone illuminate on some Pros and Cons of each?
when the Gori blades fold back, is that better than the alternate option of simply 'feathering' the blades on the Feather Stream? (appears to be more wetted surface area for the feather stream, than the folded Gori?
Appreciate any advice :)
doris
19 Jun 2001
London
Doris (and others)
I doubt you will notice much difference between the different folding props, they will all be much of a muchness except the expensive overdrive gear, which ‘might’ be worth the extra complexity. I’m not trying to be controversial, please don’t dive in.
Feathering props will be much the same performance in forward, wetted area differences are so small to be an irrelevance for normal sailors. The huge difference is going astern. They give instant grip, its almost like putting one’s foot on the brake when parking a car. I changed to a Darglo Featherstream from a Flexofold on a Jeanneau 409 and parking in tricky conditions became much easier. In fast and put the brakes on, simples!
On the JPK, it comes with a Volvo 2 bladed folder. The credit for not having that will only be about £300 so I’ll take it, use it and see how I get on. If I find that parking is a pain then I may well get a Featherstream next time it gets lifted.
The chaps at Darglo are hugely helpful and very easy to talk to. I’ll likely get one of their rope cutters anyway.
doris
19 Jun 2001
London
Have finally decided not to have a bow thruster. Just a big cable going forward to the windlass. Am having a power winch though.
Hand over now looking like November. All the big decisions made, just large amounts of minor detail. Lots of finger crossing.
Numbers
19 Mar 2024
Are you still looking at a November delivery ... thats coming up quickly!
Aluminium or carbon mast?
Are you having all lines lead back to cockpit, or are you considering having the spinnaker halyard come to a winch on your mast?
Is the standard Fridge capacity OK ... (Is there a freezer section included as standard too?)
Where are you installing your chart plotter, at the nav station, or up in the cockpit?
doris
19 Jun 2001
London
Yup, November is still the plan. Then will have to decide where to leave it for the winter.
Aluminium mast, carbon is just silly money and I do not need one.
I am having a winch on the mast so the choice is mine.
Haven’t paid any attention to the fridge capacity, maybe I should but on most boats it’s too big, IMHO. This will not be a live aboard boat.
The plotter will be down below and I’ll use a tablet in the cockpit. Three displays above the coach roof, a pilot control/display for each tiller.
