Thistle
Why has no-one suggested the obvious? Get the coastguard helo to hover just above the mast and tell you how high they are flying.
Is that the old measure, rod, pole or perch?
If the OP hasn't had his mast down and measured it with a tape measure by niw, I'll be very surprised considering he asked the question in May 2005, fourteen years ago!
I have read every post on this thread and am gobsmacked that no one has mentioned the best method of all!
1 hoist a length of hose up the mast so that the open end is level with the top of the mast. (main halyard plus rolling hitch)
2 at the bottom point from which one wishes to measure, attach a tee piece to the hose such that a pressure gauge and a water supply can be attached to the hose.
3 fill hose till it overflows the open end at top of mast
4 measure pressure using gauge
5 calculate heigh from equation Height = Ro * g/pressure
Use of an electronic pressure transducer should give height +/- 1 mm easily which may just be better resolution than TOF(time of flight) of wildlife falling at terminal(both senses!) velocity.
As a bonus, fitting a sprinkler head and pumping lots of water up the mast could also cure homesickness for those sailing in warmer climes.
