Clash
This one? Looks like a cam type rather than a ball valve - the valve is opened by lifting the handle rather than rotating it. Which would suggest that it opens the drain rather than letting the cold water in. I don't see a PRV in that picture.If you closely look at photo in post 33 you will notice that the inlet fitting appears to be a combined Inlet /PRV and drain valve.
please also see me request for advice re 240v power supply.
Edit: Just thinking that valve may operate as a PRV. The valve is opened by lifting the handle 90° such that the nose operates as a cam and pulls the valve clear of the outlet thus allowing water to flow out. They also contain a spring which pushes the valve back into place when the handle is returned to its normal position. If the spring was set to compress under a certain pressure, it could operate as a PRV without the handle being engaged.
