chris-s
In simple terms, I'm pretty sure the head gasket failed on our VP2003 at the weekend, I can't NOT try to fix it. We have not reached the stage of fitting a refurb or re-engining yet.
Before we get there, any POSITIVE tips or advice on getting THIS engine running again would be greatly appreciated. To all you doom-and-gloomers, don't, just don't, there is plenty of time for that later!
History
Last season, our first with this boat, the engine performed faultlessly. Certainly it is a high-hours engine, a little tappety but it is tidy, doesn't leak, starts on the button and drives well.
We put sixty hours on it last year with oil and filter changes at the start and end of the season.
Being a raw-water cooled variant, we flushed it with ProFlush at the beginning of last season and again when we hauled out just as a preventative measure as I don't think it had been flushed in some time,
although we have had no indications of overheating.
New impeller each season, no leaks or drips from the water pump and it's always pumped water quite happily.
Thermostat was also replaced just as a matter of course at the end of last season, tho the existing one tested fine, yes, the correct one for raw water.
We also fitted a Silicon Marine dual sensor unit to the exhaust and on the thermostat housing last season and its never shown anything of concern.
No visible oil or water leaks from around the engine/block or traces of water in the oil (until now).
This season
The engine was run multiple times whilst ashore leading up to splash day, nothing to note.
The boat was launched less than a fortnight before, a short motor to our mooring and a little motoring the previous weekend, no concerns.
The only comment I'd make is that the tickover seemed a little lower circa 600rpm.
The fateful journey
The journey was an eight mile trip to the Helford from Flamouth, unfortunately the wind and swell was such that we had to motor most of the way.
All seemed fine, although in the last mile approach to the moorings we did notice a little steam coming out of the exhaust, not billowing out in clouds, just a little.
Temps all good and plenty of cooling water otherwise. RPM note did drop a little a couple of times, but I put that down to possible slippage/knock of the throttle lever as a little touch
restored them. Moored up, switched off and then almost immediately, decided to take a different mooring, so restarted without issue and relocated.
A little niggle in my head made me check the oil, no issue, clean and plenty of it.
Later in the evening, with the steam/rpm thoughts still niggling away, I started the engine, it started fine, but it was not sounding quite right, gave it some revs, lots of 'smoke/steam', throttled back to
idle and it petered out. Checked the oil and it had emulsified and the fluid level was higher than earlier (should have checked before starting it possibly?)
With two top-end gasket kits onboard, the only thing missing was a torque wrench, probably just as well.
The Plan
So here we are, less than two weeks into the season with a dead engine, before we get into the discussions and virtues around repair or replacement engines etc, step one is to assess the damage.
The assumption is that the head gasket has failed, hopefully without too much other damage and the optimistic thoughts are to do a top-end overhaul without removing the engine. All well within my capability.
We are also assuming that it wasn't the raw water pump that allowed water into the engine given that there have never been any external signs of it leaking and that it wasn't exhaust elbow related as that was replaced in 2022.
Before I take the head off, is there anything I can do to help identify other possible damage which I couldn't do so easily after taking the head off?
A compression test for the rings comes to mind, but not sure I want to spin the engine much in its current state and its probably meaningless with a blown head gasket anyhow.
Happier days..
![IMG_0350.JPG IMG_0350.JPG](https://ybw-data.community.forum/attachments/127/127704-6d3f6466fdbc6b8d3e3fae15c6fe2d08.jpg)
PS I have watched the YT videos from RAN Saling and Sailing Brittany cover their VP2003 rebuilds, straightforward and encourging stuff.
History
This season
The fateful journey
The Plan
Happier days..
