Wansworth
I have to admit to a liking for all things nautical,shackles,cleats,blocks……boating paraphernalia is by design fit for its job and in their form artistic.
Like aeroplanes, if it looks right, it will almost certainly work right. Whether it’s a whole boat, or a clever little widget.I have to admit to a liking for all things nautical,shackles,cleats,blocks……boating paraphernalia is by design fit for its job and in their form artistic.
I was going to add that modern streamlining had done for a lot of what I meant…..I defy you to approve of Starck's yacht A. To avoid doubt, wikipedia even has to write "starboard" under a pic of the, yes, right hand side of the vessel.
I was going to add that modern streamlining had done for a lot of what I meant…..![]()
A late friend of ours got into Etaps, having in turn a 23, 28 and 34. The trouble was that Etap, being a design company and not a traditional boat builder, decided to redesign everything, from interior fitting such as catches to cleats, with the result that nothing was really ideal for the job.
I think the Etap 30 was the best example of its type, and the 23 looked neat enough. The 28i was trying to be sporty but was less comfortable and slower than my then Sadler 29. The 34 was the one that seemed over-designed, with odd cleats and fittings. My friend was stuck with the whipstaff steering that was just weird. It wasn’t a bad boat and went well enough, but it had a tall rig (that developed an S-bend and needed extra stays) and wouldn’t have suited me.I have a soft spot for Etaps, largely because I appreciate care and flair in design, though have never owned one.
I am not sure Etap can really be dismissed as a boatbuilder, as you seem to imply. Producing 26 different boats over a period of around 35 years is more of a track record than some of our more mainstream brands.
You say that nothing they produced was ideal for the job, but your friend presumably thought differently as after owning one s/he went on to buy another two boats of the same marque.
Personally, I love a cascade of Harken or Ronstan soft attach blocks, all put together with nice splices. Though I also have a number of low friction rings where the angle of turn isn’t too mch.function definitely the bit that matters on a boat imho but there is something very satisfying about some dyneema, a soft shackle or 2 some low friction rings sitting nicely under a lot of load compared to some pulleys & rope & tracks![]()
The problem with taps was the double moulding for the buoancy. If ever there were a fissure, the boat could become water-logged.I have a soft spot for Etaps, largely because I appreciate care and flair in design, though have never owned one.
Most sailing kit has all the corners and rugosities designed out so nothing catches, except for bow shackles in bow rollers.Of course boats and boats things typically look lovely, and much of that derives from their forms following their function.
Theres a certain reflection of the modernist principle in cruising cats, I feel. You can’t call them pretty, they are in fact brutally ugly, usually. But they're also brutally effective at providing luxury on water accommodation, totally unlike the dank, noisome hole that say, a 1950s wooden yacht would call ‘the cabin’. The varnished wood is very handsome when freshly done, but in truth, they were wet and horribly uncomfortable.Of course boats and boats things typically look lovely, and much of that derives from their forms following their function.
On the other hand, 'form follows function' was a core principle of the Modernism movement in architecture, and implied rejection of ornament and traditional aesthetics in buildings. Unlike boats, Modernist architecture is generally not well liked today.
I wonder to what extent we reject the Modernist aesthetic in part because we are uncomfortable with the underlying function - housing for worker drones, office blocks for faceless corporations?![]()
She has quite a lot of buoyancyI like Béyoncé.
Whatever floats your boat.
No. That's buoancy.
ISTM that in most superyachts, the function is toYou always have to consider what the function really is ; it explains a lot of avant- guarde visual malformity.
