Vega1447
I've see this discussed online though not recently. Apologies if it is a FAQ.
I have a pretty basic plastimo furling system on my Albin Vega 27.
I use a 6mm furling line (braid on braid) led aft from the furling drum through fairleads then though a clutch and finally through a turning block at the pushpit and forward to a winch if needed.
This all works fine but regularly the line "clumps up" on the drum when rolling out the headsail so the drum won't turn unless I go forward to free it.
Because the line is too thick for the relatively small diameter drum.
(Of course I use this thicker line for ease of handling.)
Not a safety issue as I can still furl the unrolled part of the sail.
The alternative is to winch the sail out which does work through I'm uneasy that it may put unnecessary load on the mechanism.
(Am I overthinking this?)
I remember reading somewhere that removing the core from the "forward" part of the line - the part that wraps round the drum when the headsail is rolled out of course - is an easy way to remedy the problem.
Would I need a fid to extract the core from a point a meter or two aft of the forward end of the line (obviously I'd mark where the line emerged from the drum with the sail fully unrolled) or is it just a matter of using a spike to penetrate the outer sheath and extract the core from the foremost part of the line?
Presumably I stitch the remaining core to the sheath for a few cm before cutting so that it doesn't work its way aft?
Have I greatly weakened the de-cored flat tape forward of the cut?
And does it matter?
Any comments very welcome.
And does it matter?
