runner911
Can anyone advise please ?
My fishing partner runs a Merry Fisher 925 fitted with a Volvo Penta D4 260, which now has 1600 hours running time on it.
The engine starts and runs faultlessly. It does not burn any oil and does not produce excessive smoke.
Towards the end of last season he noticed that the normal operating temperature of the engine had increased by around 5 degrees to 90 C.
Anything over 3500 RPM and the temperature shoots up to over 95 degrees which triggers the alarm.
The following work has been carried out to try to rectify the problem.
Heat exchanger removed and thoroughly descaled and cleaned.
Thermostat removed and engine run using a cleaner descaler for 4 hours.
New impeller fitted.
Full engine oil filter service etc.
Took the boat out yesterday. The engine now runs cooler by about 3 degrees but the problem has not been totally rectified.
Anyone any suggestions/ideas ?
Is a "cooler " running thermostat available for D4 engines ?
