Sea Change
You were wondering what the carbon footprint was to ship the motor to California and back.What question did I ask?
Apologies, I meant that rhetorically.You were wondering what the carbon footprint was to ship the motor to California and back.
Close. The fuel is about 40kg the tank could be anything but lets say another 20 with pipes. So 132lb which I guess is almost 2100 in someones universe.He said little of nothing about saving the planet but was fed up with the smell of a diesel engine and said the compromise and performance suited him, which I think is fair enough.
The battery weight is greatly offset by not having an engine or fuel onboard. The fuel weight saving was not mentioned so I thought I would check it out. T'interweb came up with this AI generated gem:
"12 gallons of diesel weighs approximately 875–2,100 pounds, depending on the size of the fuel tank."
So much for Artificial Intelligence taking over the planet.
Yes I instinctively used US gallons because it's the only time I refer to them these days. Still better than AI though!12 uk gallons would be more like 45 kg.
ChatGPT doesn’t know anything and the old ones couldn’t do maths so the answer was simply the statistically most likely words to answer the question. Presumably 2100 pounds is a common weight for things.
By way it's not half a ton it's quarter of a tonWhat a marvellous idea. Put an electric drive into a boat known to be sluggish in light winds, and heavy to push along under engine. At least half a ton of batteries will make little difference to progress.
