Adrian
"Here you go...
http://www.ionianislandholidays.com/island-info.php"
:encouragement:
:encouragement:
Ah! Fiskardo.
A lovely place but in the total of 7 weeks I've spent there 6 crossed/lifted anchors and one cut warp. The morning's stately pavane of the anchors.
It really has little to do with the place but everything to do with incompetent sailors. From experience of this sort of situation, the PP are very sensibly hiding from having to take any action and expose their posteriors.
Usually the Neilsen lead boat crews are very helpful (beyond the call of duty) and I'd advise against taking any action against the absentee (I probably know who it is and they'll be down from the villa to sort themselves out).
Good luck to you Cardo.
PS though Jim's suggestion is very sensible, I ALWAYS go bows to with a Delta on 25m chain and 50m warp - doesn't stop people picking it up or grimly wrapping it around their prop. As I said, incompetence always triumphs to produce disaster.
~Get the divers to sort it out - to them it will be fun. St Barths its big business for the divers crossing anchor chains.
That's in the "Windies" I assume? How much do they charge? In Greece the going rate is €50.
Well, if you insist on having 50 metres of rope lurking just below the surface. no wonder unsuspecting arrivers snag it. If I ever get your selfishly positioned rope around my prop, Charles, expect it to get cut! Chain always lies sufficiently lower to be safe. IMO bows-to on rope = a "boat bum" and subsequent experience of the crews of suchlike moored vessels, usually proves me right.
As usual your assumptions, Steve, make a fool of you.
You might not be aware but not all rope floats - and I usually only have the chain out.
If you do make a habit of cutting other peoples' warps, I fear for your future good health.
The curve of a rope's catenary is very shallow indeed compared to that of a chain. Therefore the rope will always stay much higher in the water along it's length than will a chain, except in severe conditions, where th difference is reduced. A rope, also, once snagged will stay with you and get tangled much more easily than will a chain, which will always tr to drop away. I thought you would have known that?
People on rope are treated as pariahs* by the mainstay of sensible yachtsmen. I thought you would also be aware of that! (Or, are they all foolish too?)
*- they tend to wear brown leather sandals too!
"A habit"? No, hardly likely since MOST yachtsmen are sensible and don't deliberately put underwater hazards in the way of their neighbours.
So self righteous. What a load of BULL****
My god Jim , I'm not sure what text book your are quoting from ,Stern-to boats will usually lead the chain from a metre above water level through a bow fitting. Bows-to boats will usually lead rope through a deck level fitting some 30cm lower. Rope rode boats with experience of shallower harbours will fit an even lower lead to hook the line under, down to water level, (a) to reduce the angle of pull at the anchor and allow a shorter scope, and (b) to lower the rope below passing pariahs - err - propellers.
You've made three interesting assumptions here. The first is that yachtsmen do not expect shallow ropes to be a hazard near moored boats on a Greek quayside. The second is that shallow ropes are more hazardous than shallow chains. And third is that those who use ropes do not take precautions to keep them below the level of passing boats.
Let's assume there's a row of boats, some stern to, and some bows to, on a quayside, and they've all dropped their hooks at similar distances from the shore. In this case, it is likely that the stern to boats are using chain, while bows to boats are using rope with some chain.
They may also slide a heavy chum along the rode to sink the rope further. My redundant 45lb CQR did the job nicely.
So, catenary can be completely irrelevant.
As for passing propellers which don't expect underwater hazards when manoeuvring near quaysides (your mainstay of sensible yachtsmen?), perhaps they should be treated as pariahs, even if they are wearing deck shoes?
I wrote the text books for the first Greek charter company to teach complete novices in a week - enough to skipper on flotilla for the second week. Much of the teaching was practicing end-on mooring. And the majority of flotilla boats around the Ionian then used rope/chain rodes, rather than chain (no winches for 8m boats in those early flotilla days). Those guys could moor bows on, single handed, when they went off in charge for the first time.My god Jim , I'm not sure what text book your are quoting from ,![]()
Yes, I agree. I was just pointing out how it can be done - and how I do it when I have the choice. Especially in boats which don't do backwards in a crosswind!So to expect charter or even boat owners to have sunk their rode I think you asking a bit too much . If you don't mind me saying.
In principal , great idea , in reality it very rarely happens .
Indeed, some lack imagination. Hence the waterline hook and sinker. Belt and braces. And even more important, very easy to bail out from when there's a serious tangle on the bottom!Any one with half a Brain should expect if boats are moored bow to , there a good chance that line will be just below the water for some mts back
Recipe to bumping the quay when the wind gets up if you're not aboard.The chain will be lying along the bottom for a good proportion of it's length from the anchor.
Another lovely argument for mooring bows to. Your rudder gets out first, less chance of a tangle.Yes, we all expect ropes near Greek quays But when it is one which cannot be avoided and nobody carries a boathook long enough to ensure that it clears a 2metre keel when leaving a busy harbour, a neighbouring, downwind boat's rode is a serious hazard. One only needs to be forward of the neighbour's bow by half a boat length or so for one's rudder to clear a chain. With rope it is likely to be much further.
It's easy if you can lift 45lb. Lower hook of CQR over rode using recovery rope. Push it out 3m or so with boat hook. Recover by pulling recovery rope and lift aboard. But this rigmarole is only needed in shallow harbours if the rode has to be pushed down to avoid careless sailors.Unless you leave long before everyone else is awake in the morning, handling and recovering that floppy 45llb CQR as it slides down your rode to your other anchor must be quite a feat of dexterity, not to mention strength!
Mis-quote. When the big winds come from the beam, and several boats to windward are dragging sideways and starting to bang the quay, you take the pressure off by taking lines to windward any way you can.then YOU enjoy complexity, if I recall, like threading lines across neighbours' boats under their wires, to the quay if a blow threatens!
Charles , to be honest with you IM not sure what going on we turned up in the Ionian late April and right thought to most of May and I found it to be very quiet , both Nelson and Ioniansailing told Me that booking are slow and Ioniansialing said their season this year will start around June , as we sailed up along Corfu using anchorage we have use many times before , we found then to be almost empty , we now been in Croatia for over two weeks and the most boat we have anchored with in a night was last night , five boats in all usually it been one or Two and most night none , Croatia is turning out to be a big surprise to us , nothing like we expected it to be , we expected to be having running battles over anchoring fees , so far there been none , we just had two night in the National park , where we expected to pay , we seen no one . As far as ( far worst incompetent behaviour then the Ionian goes , well maybe I will , in all the year I have sails and it been a lot I never seen stuff go on like I seen in the Ionian .
I also never had so much damage done to my boat as I have had done in the Ionian . more bent stanchion then you can every be live .
I hope I don't end up eating my words after what I just said about Croatia
