Cheesed off with Raymarine
salad
1 Jun 2019
The 6 years comes from the EU directive. However as I suggested it is largely meaningless as it is so difficult to make a case and manufacturers who are ultimately responsible (even though your contract is with the retailer) are rarely in the UK so difficult to pursue.
Thats why I thought it had now become unlimited. I'm not sure I agree about making a case, particularly in small claims. Magistrates are incredibly sympathetic to the little guy and if you're going after a big firm, it's unlikely they would even respond, leading to summary judgement. Costs peanuts too.
He might be inside 6 years depending on what month the unit was purchased, but does he have a contract if he's not the original purchaser? Hmm.
I've seen a few negative things about Raymarine now, so I think when the time comes I'll be looking at other options.
Tranona
10 Nov 2007
Surely only the original purchaser could make such a claim
I believe that is correct, and to answer the previous post, while the small claims track is straightforward, the challenge is to provide evidence that the fault was there from the start and that the the time to failure was shorter than one has a right to expect. That requires expertise that will convince the court. As I said difficult with things like electronics in these days of fast moving technology and disposable products. The problem with boat electronics is that time is not a good measure of usage compared with say, a phone or tablet that uses similar technology and components. In other words there is not a benchmark standard for how long one would reasonably expect such a product to last.
Raymarine has already made an offer of compensation for the failure. The secondary question from the OP is whether there is an alternative that will meet his requirements and have a longer life. Suspect the answer is NO. Essentially they all use the same technology and manufacturing processes and getting hard evidence that one brand is more reliable and longer lasting than others is a challenge!
Paulfireblade
13 Mar 2020
Buckinghamshire
Interested to hear responses. After all I would replace my laptop long before 6 years but I have an iPad that is probably 8 years old but neither are exposed to the elements of a cockpit.
I suppose the niggle is so many C80 chart plotters still running that are really old now.
My 7 inch inside works fine so I could put that on the binnacle and get some time out of that but ultimately the straightforward option is to replace both with Axiom units.
Hey ho
Mr Cassandra
5 Nov 2001
Eastern Med ish
I had the previous model that would jump to different countries all over the world and steer the boat to that position,the repair centre said they couldn't repair it ,but would sell me the 12" axiom Pro for a service charge of £995 +vat .This new item has started playing up after two years. So I never leave it in charge of the autopilot .
bedouin
The problem appears to be the touch screen and that is much more delicate than the display-only LCD you get in the C80 etc.
PaulRainbow
16 May 2016
Suffolk
Couple of years ago i had a faulty Raymarine wind instrument (3 years old) belonging to a customer and a Garmin autopilot controller of my own, that i purchased used on Ebay, with a tiny scratch on the screen. Raymarine didn't want to know, not even a discount for a new one. Garmin offered my a "refurb" unit for about £120, as the new one retailed at over £500 i reckon that was a good deal.
I avoid Raymarine if i can, but some customers insist on it. My choice is always Garmin.
As for a 15% discount, that will be off of retail, i could offer a better price than that, they are having a laugh.
Compatibility with other systems, if you have ST60/ST70 etc display they will network just fine with other manufacturers. Radar, if fitted, will not, neither will it work with Raymarine Axioms.
Autopilot will work up to a point, it will steer to a waypoint or to wind, but cannot be directly controlled from the MFD. This is true whether you switch to another manufacturer or stick with Raymarine.
In short, there is no benefit in sticking with Raymarine.
Caladh
25 Oct 2009
Out there again and no longer dreaming
If I’m not mistaken aren’t Raymarine and Garmin part of the same company ?
fushion julz
8 Mar 2021
I have had a similar issue with Raymarine. I have (had) a Dragonfly 5m that was purchased in 2016 (but not by me...it came with the boat).
This year, on relaunch in March, it failed to power up ...I have established it is not the cable. connector or card, but Raymarine have said it is not a serviceable unit and only offered a similar 15% off a new device.
I was gifted an Element 7s by a friend who upgraded to Axioms, so didn't need to buy anything, but was a bit miffed that a £500 ish device could fail in such short time and not be repairable at all.
I use an old Samsung S2 (8") tablet as my primary navigation unit...it is more reliable, more accurate and more user-friendly. It works all the time (although in very bright sunlight it can overheat) and the Navionics subscription for Android works on my phone as a back-up and when I'm in my dinghy.
Paulfireblade
13 Mar 2020
Buckinghamshire
Wow, mine has done that a few times as well. Pretty scary when auto pilot turns the boat 45 degrees or worse. Never use waypoints for “Go To” but bearings input direct in to autopilot and then keep an eye on the track shown on the plotter.
Paulfireblade
13 Mar 2020
Buckinghamshire
I had been told my Radar was still compatible with Axiom . If not, Garmin might be worth considering.
Paulfireblade
13 Mar 2020
Buckinghamshire
For a while now the Helm chart plotter has been misbehaving, reverting to Home Screen regularly and now creating MOB locations all on its own plus some other occasional weird issues. My local Raymarine dealer has tried a factory reset and latest firmware to no avail.
If you take the helm unit off the network with the other MFDs, does it still misbehave and are they all running version 19 of LH2?
With this being at the helm, are all of the connections/cables in good order?
I have 5 of the Raymarine MFDs and all work without a glitch but they are inside and not exposed to the elements.
Just the exterior unit, one at chart table performs fine, cables all look good. Apparently Axiom units have access for cards in the rear to try and stop moisture ingress but from what has been said above still not a fix.
Mr Cassandra
5 Nov 2001
Eastern Med ish
What's strange, is we are talking about a piece of kit close to €4000 and it isn't reliable after 18-24 months normal use.
They are taking us for mugs .
