Lakesailor
The point is that anybody taking on a worn out boat like that must be prepared for a lot of work
I don't think that was part of the OP's plan
will she need a ridiculous amount of work to get her seaworthy again?
As I commented in post #87, my friend did it fairly painlessly with a HR Monsun. I too have replaced 10mm teak planks plus re-bedded countless screws where the plugs have worn thin and fallen out. All screws in my 1981 HR deck have unscrewed easily from the GRP deck. The planks are bedded on a very thin silicon base that, over the years has hardened and shrunk, from which the planks lift easily away; the silicon no longer adheres much to anything. I have no qualms about taking off the lot in a few hours; only prior removal of the deck fittings will be onerous - but I've done that before when I had to remove an earlier abortive 'solution' of a Coelan coating. Then it's just a job of epoxying the screw-holes, fairing them down and painting."Relatively easy to strip them off"?
That depends on how the teak was fastened down originally. Fair enough if it was fixed down to a ply base, which has probably rotted anyway, but I can tell you that if the teak was glued down direct to the deck moulding with epoxy resin, only blood, sweat, and tears will remove it.
The point is that anybody taking on a worn out boat like that must be prepared for a lot of work and compared with other jobs on the boat this one is not that onerous ...
I think general opinion is against you here. There may be some boats on which lifting a teak deck is a doddle, but the feedback is almost invariably "Worst. Job. Ever." And even worse if you are trying to prepare it for a painted finish, because even Kiwigrip can't cover up ruddy great gouges and holes. Can it?
I have used Tek Dek for cockpit locker lids on another boat and was very impressed with it, others couldn't believe it was not real teak. But, no way will I consider it for my present deck replacement - with adhesives it was almost as expensive as the real thing. Too much work involved also, I have already spent too much of my sailing lifetime on hands and knees on my damned teak deck.If the decking had merely been screwed down and bedded on silicon, I would probably have stripped it all off, and fitted arificial teak, but having found that it was bedded down with epoxy, I was so glad that I was only committed to replacing the one piece
My present boat doesn't have a teak deck. I wouldn't have bought it if it had. Treadmaster is wonderful stuff.
Treadmaster can be great, but if not fully bonded down water can remain within the bonding area and can cause osmosis on the fibreglass deck. How do I know? Just removed some worn out, chipped and lifting Teadmaster in my cockpit. Have to say the Fein did the job quickly using a wide chisel tool.
Yes, no doubt, but that is hardly the fault of the Treadmaster.
There came a point when some yacht constructors began to fit thin teak cladding that could be glued down, not only on decks but any compound curved surfaces - not only cheap, light and fast but that could emulate the more exclusive yachts that used skilled labour for weeks to lay expensive, thick, teak planks that needed screwing down. Then came a time when even those exclusive yachts could dispense with the pesky screws and glue down their - only slightly - thinner planks with modern adhesives.However, my boat does have some small areas of teak decking, - a couple of cockpit seats / lockers, and a helmsman seat. By the end of last season they were definitely looking past their best. I decided to remove the decking from one, and replace it with one of the artificial type. This was about 1.5m x 0.4m, so not a big area. It turned out that not only was it screwed down, but it was also securely bedded down with epoxy resin, onto the deck moulding. The only way that it could be removed, was by chipping away at the teak with a hammer and wood chisel.
However, when it does wear out, or degrade from UV as it does I sunnier climes it is as much work remove as glued down teak. Have done it on a couple of panels like your locker tops and it put me right off. Only consolation is that you don't have the holes. Laying new Treadmaster is also a skilled job and very expensive now.
See Barnacles's post above. Voice of experience. He and I have had exchanges on this subject before and I would rather take note of people who have done it than the musings of those who have not.
Me too. How many teak decks have you replaced?
Only laid one - and never again. Seen plenty done in various stages of stripping and replacing though.
As Barnacle says there are several different ways of applying teak to decks and the difficulty of stripping and replacing varies according to the original method of laying and the construction of the substrate. Other than saying it is usually a PITA whatever the method, it is a mistake to make sweeping generalisations.
I am glad to see that we agree.
But not about your sweeping generalisations in posts #94 & 97 which is what prompted my further explanations.
A knackered teak deck (just like a knackered engine or sails or even dreaded osmosis) is not an automatic reason to walk. You assess the boat on its merits and what you need to do to get it to where you want it. Of course if you are not a handy person and want to sail rather than fix boats then you would not be looking at a boat that needs work in the first place.
