Has anyone worked out how to use a cheap bike computer like this to count how much chain has been put out?
Why do you need to make things so complicated? Don't you mark your chain every few meters?
Must be a much bigger boat than mineThe main advantage of chain counter is when there is no one up forward to see the marks.
When Med mooring for example the helmsmen can release more chain while reversing without any fear that the chain will run out. Leaving a crew member free to tend lines or fend off.
To take advantage of this the chain counter and windlass controls need to visible/usable from the helm.
The bike computers are adjustable for different wheel diameters, but the ones I have seen need some slight mental arithmetic to convert the reading, but a table is not needed.I dare say that the device in question could be used to give an arbitrary number related to the number of revolutions of the windlass, but a number of magnets and a look-up table would probably be needed; just try it and see what you get.
I have not seen anyone do this or a few years appart from a stern anchor. Nothing wrong with it, but generally unnecessary with modern boats.Don't people usually range chain on deck before anchoring? I'd never trust chain to run cleanly from my anchor locker, as other things are stored there. But even if other stuff wasn't stored there, the chain could easily get tangled in a locker and not run cleanly.
Then again, I don't have an electric anchor winch.
Doesn't marking every few metres make it complicated?
We mark every 10m with cable ties. 1 tie for each 10m so 1, 2 3, or 4 ties for 10, 20, 30 or 40m of chain - couldnt be simpler.
