Porthandbuoy
I replaced 3 x 110 Ah lead acid batteries when I bout Sheolin. These batteries had been ignored totally for 5 or 6 years and showed zero volts when I put a multimeter across them.
Step 1: Thinking 'nothing venture, nothing gained' I hooked one up to a 15A Cetek smart battery charger. No good. The charger didn't even recognise a battery was connected.
Step 2: I put an old 12V battery, which held some charge, in parallel with one of the duff ones and hooked up the charger. This time it worked, recognised a battery was connected and started shoving some amps in. After a while I disconnected the old batter and the duff one continued charge. The charger completed it's charge cycle and I then selected 'Recondition'. After an hour or two that was completed and the battery showed 13.2 decaying to 12.7 overnight. Result!
Step 3: Repeat Step 2 with 2nd duff battery. It recovered as well.
Step 4: Repeat Step 2 with 3rd duff battery. Not such a good result. This one went into some sort of thermal runaway and began to hiss and spit and distort alarmingly. Dropped it in the water butt to cool down.
Still, two out of three isn't a bad result @Jayayecee, your's might recover, but don't leave it on charge unattended.
Batteries 1 & 2 are still holding their charge. I did a drop test on them and I reckon they're down to around 80~90 Ah.
