dewshi
Does anyone recommend Antal winches? I’m considering a pair of XT16’s, which are significantly cheaper than Lewmar EVO equivalent for cruising.
Make sure that their '16' means the same as everyone else's. I had some years ago but found that they were the equivalent of other 14s when the data was compared. Otherwise they were ok.Does anyone recommend Antal winches? I’m considering a pair of XT16’s, which are significantly cheaper than Lewmar EVO equivalent for cruising.
Had mine for 18 years no problems. Just make sure you use the correct size halyard/sheet (not too large a dia.), or the top circular spring will be pushed up and off by the self-tailer ? .
