Jaluda
Can you put stainless steel shackles on anchor cable?
Why not? I do.Can you put stainless steel shackles on anchor cable?
I've always used a ss shackle but I use a short length of nylon water pipe as a washer in the last chain link and in the anchor eye as insulators.
Just one note of caution about this. When I bought mine it was made to Wichard's HT spec, which is 17/4 PH, a higher strength stainless. Since then, as in the link, they have stopped producing the countersunk pin version in this material and make it in 316. They still make other shackle designs in HT.A decade ago I followed Vyv Cox's advice and fitted a Wtchard Stainless Steel shackle countersunk Allen head (plus loctite) and have no cause to regret it whatsoever. It's the mut's nuts! No more corrosion visible either to the anchor or the chain than we used to have with a galvanised one.
Wichard - 12mm Self Locking Allen Head D Shackle - 316 Grade Stainless Steel
