Plus two pins, plus stainless bling.![]()
The Kong design is pretty clever. The pins are forged lugs, part of the body. The single screw carries no load, just holds the body parts together. I Loctite the screw and it takes some effort to undo at the end of the season. If you want a swivel, and I do, then this is the one to go for. Did well in the tensile test too.
That's fine, but I honestly don't see what a swivel achieves. .
One of the advantages of a swivel is solving the problem of the chain becoming excessively twisted in an anchorage where the boat repeatedly spins around.
Once the anchor is broken free, the twists will spin out even without a swivel (sometimes very dramatically), but the gypsy cannot retrieve twisted chain, so when trying to retrieve the anchor all the twists become concentrated in the last section of chain. You need to achieve a very short scope, close to 1:1, before good quality modern anchors can be broken out. If there are many twists in the chain (and it takes a lot) the chain can start to hockle, or bunch up, before a short enough scope is reached.
Not a very good photo, but you can see the hockled chain. When this photo was taken, the chain was under a very large load trying to break out a completely buried anchor. If look closely, you can see the bunched up chain. In spots it is so twisted that some of the links are lying at 90°(see the link the arrow is indicating). The torque was great enough that I was concerned about permanently damaging the chain.
This is a rare problem that you are not likely to see unless you anchor a great deal, and have an anchor that is difficult to break free at shortish scopes. Whether it is worth the drawback of a swivel to solve this issue is debatable. Personally, I still use a simple shackle, but there have been occasions, such as the one pictured, where a swivel would have made life much easier.
10mm chain is used as 8mm won't fit on the swivel I seem to remember when I tried this set up on my boat. 10mm chain also allows a bigger shackle pin to be used on the anchor. I've got to have another go at setting my system up so that the anchor is self stowingVyv,
Any critical reason why the three links are 10mm rather than 8mm like the rest of the chain? With 60m of 8mm chain on board I could easily put three links between the swivel and the anchor, but I don’t have 10mm links to hand.
Mark
Considering the number of swivels I see I can only think its the marine lemming instinct that encourages people to buy them. Yes - there are yachts where a swivel is useful, but few where it is essential. There are no example where a bent link would not suffice. I am not aware of any literature praising swivels but am aware of literature (including this forum and this specific thread is simply one example of many) that damn them.
So why do I see so many? - most are unbranded and most have at least one, sometimes more than one, inherent manufacturing/construction weaknesses as outlined in this thread. People agonise over anchors, people agonise over chain (and less, but a few, agonise over shackles) - and then go off and buy an unbranded swivel.
I suspect its the allure of the stainless and the fact one's neighbours have one.
Its a bit like tearing up $20 notes and throwing them in the sea.
Jonathan
Vyv,
Mark
No major reason. Load and wear are highest at the anchor connection, the swivel and shackle would accommodate a size bigger, so it seemed like a sensible precaution. 8 mm will be fine but inspect occasionally.
That's fine, but I honestly don't see what a swivel achieves. I see it as a solution looking for a purpose. On my previous boat, the bow roller was 8-9ft above the water, and the stem was nearly vertical. We had a mark on the chain showing when the anchor (140lb) was just clear under the stem. If the anchor was incorrectly orientated, it was fairly simple to lean over and rotate the chain with a "poker". I don't see where a swivel would have helped.
Our present, much smaller, 36ft ketch, has her bow roller extended forward from the stemhead. By fitting a "bent link" between the chain and the anchor, if the anchor comes up facing the wrong way, the link automatically rotates the anchor every time. I appreciate that not every boat can accommodate a link like that, either from lack of distance from bow roller to windlass gypsy, or because of the potential for damage caused by a rapidly rotating anchor, on a boat with a bow roller mounted close in to a vertical stem.
In the latter example, one is faced with poking the anchor with a boathook, and I accept that if you have to do that, then a freely rotating swivel might help, but if design permits, a "bent link" does the job for you.
Don't want to start a major argument, but surely the greatest load is not at the anchor, but at the bow roller.
