Air pockets coming from stuffing box
27 Dec 2022
I have these pockets of air traveling along the greasing line from the stuffing box. Is that an indication that some seal(s) in there are worn out and needs replacing? Have a bit of vibration from what I believe is a worn stern bearing, so I will be heading for a yardstay anyhow.
ean_p
28 Dec 2001
Humber
Isn't the bubble travelling up the line to the stern gland.....? In which case its just an air bubble in a poorly filled greaser. Is it grease or oil or indeed a slurry of the two? To establish which way its moving just mark on the hose the leading edge of the bubble with a pen......I would be surprised if it is being driven up into your reservoir rather than down into your gland if its grease......
Aja
6 Nov 2001
Done! I imagined I had been thorough when packing the greaser. But we will see :)
Did mine yesterday. Its a messy job and really quite difficult to pack the grease into the greaser. It would be difficult to pack without getting air in the mix. Just ignore the air bubbles.
27 Dec 2022
Aaand you were right! The air pockets are moving downwards :)
Dont realy like this lubrication system. Messy to refill, and obviously a bit difficult to fill the cups properly! Maybe I should look into some auto cartridge solution...
ean_p
28 Dec 2001
Humber
Don't waste your money.......the odd air bubble won't do anything much so long as they keep moving.....you just need a little more care when topping it up, but don't sweat over it.....auto lube (slurry) systems are notoriously fickle.......
Tranona
10 Nov 2007
If you don't like it change the seal for something more modern. The grease does not lubricate anything. It is there to reduce the flow of water up the stern tube so that when the boat is at rest the packing does not drip. The packing is self lubrication. You have to regularly replace it as it gets washed away when running hence the normal routine of giving the handle a couple of turns when you leave the boat. A modern drip free seal does not need this.
However that is a very tight installation and you may not be able to change it.
ean_p
28 Dec 2001
Humber
Having another quick look at your photos.....are you certain you have a stuffing gland seal and not some form of mechanical seal housed in the brass item protruding from the hose. I don't see any follower / gland nut assembly associatedwith the brass item..?
27 Dec 2022
Aie-aie sir! i will let it go. I am starting to get concerned about greasing of the shaft seal though. For a couple of months now the greaser have felt hard. Can it be that I have greased too much and the stuff have hardened in there?
Tranona
10 Nov 2007
Difficult to say without knowing the construction of the box and the type of seal used. My comments assume it is a conventional packed gland, but like ean-p I now have my doubts because it does not look like it has the usual adjustment. It is not clear where the grease tube enters or exactly where the internal seal is located.
Supertramp
18 Jul 2020
Halifax
There is very soft (air pocket), medium (pumping grease, no back pressure) or hard (pumping grease and the bearing is full creating back pressure). As soon as the shaft rotates the back pressure drops. Based on dismantling mine after 4 years, the grease doesn't harden.
A good point. I have always added a turn every hour when motoring, and then about 2 turns at rest to stop drips. On dismantling recently I had masses of grease along the 4 foot stern tube creating the risk of bunging up the cutlass. I will be using fewer turns less frequently from now on. I don't mind the drips from the conventional gland - it's reassuring to know the bilge pump works!
Tranona
10 Nov 2007
Much nicer to have a simple neat, cheap non drip solution like this! The tube is a vent and the shiny metal bit an Electroliminator connecting the hull anode to the shaft/prop
Supertramp
18 Jul 2020
Halifax
That is very neat and I can see the appeal.
I have an enormous deep sump under the propshaft so a bit of water is not a worry. And the grease not messy as it goes down the shaft, not into the boat. I will consider one next time I take the shaft out.
Supertramp
18 Jul 2020
Halifax
Mine unscrews at the base. I then wind the plunger back out a bit to create a dip in the exposed grease surface and fill using a knife blade. Then wind the plunger some more and repeat until the fill is completed. Reassemble with the grease a little proud of the surface so no air traps as I screw it on.
Your system is different but should follow a similar principle. What is very different is the diameter and material of your grease line to the gland - mine is short, thin and hard plastic (about 4mm). So an air bubble pumps through quick. And your grease looks black where I use white lithium grease.
Refueler
13 Sep 2008
Far away from hooray henrys
Could you offer up some guidance? :)
If its the standard barrel type with threaded plunger .... unscrew the barrel from the base plate. Wind the threaded plunger all way down (may have to catch any remaining grease and 'spoon' it back in ....
Take pot of grease - hopefully with the plate and hole in centre on top of the grease ... place barrel over hole in plate ... press lightly while unscrewing threaded plunger - this should create suction pulling solid grease into the barrel.
There should be no need to use a blade or spoon to fill the barrel ... its same action as used for filling standard grease guns.
In use ? Before starting any trip - I give greaser a couple of turns on the plunger - just to get a small amount of fresh grease in to the seal. I then go on my trip ... I don't give any more grease during the run ... the slight ingress of water provides the necessary .... along with the packing.
Once arrived at destination and engine stopped - I then give a couple of turns again.
I used to give turns every few hours during a trip - but ended up with grease spread around the bilge where too much excess was thrown out at the adjustment nut ...
Strangely I also noted that packing tended to be scorched when replaced - which may have been due to too much grease preventing water from getting to the packing. Since changing to not greasing during trips - I noticed last change of packing - it was not scorched.
NormanS
10 Nov 2008
Ideally, packing should be adjusted so that when the shaft is rotating, an occasional drip comes in. This ensures that the packing is being sufficiently lubricated by the water.
A standard packing gland doesn't need to have grease pumped into it during normal use. All you're doing is filling the stern tube. It is, however, good practice to pump in a little at the end of a cruise, if intending to leave the boat unused for a while. This prevents an occasional drip.
