jrudge
Surely your Williams dealer will resolve this is courier the part to you. They are well aware that there products are used away from a marina.
How did you diagnose the issue without a scanner ?
In answer to your questions my personal knowledge is the textron engines. This is Rotax. Bear in mind that they are also used in jet ski so find a jet ski dealer and they will help.
On the textron the engine does not need a reset post a fault. I doubt the rotax does.
The lamda sensor is there only for emissions control. You can run it but the ecu will I assume limit power. If not then ignore it and enjoy your trip.
