jimbouy
Hi
In my newly started quest for a trailer sailer I looked at my first Leisure 17 on Sat morning.
Seemed solid enough but boy what a mess!! You would think that some one looking to sell anything for £1200 would tidy it up.
Anyway, it has raised some more questions inmy inexperienced mind.
She had had several coats of yacht enamel over the years and obviously no effort to rub down and produce a nice finish.
Question(s) one.
Presumable such paint work could be rubbed down?
Can one use a power sander?
Am I right that you have to be carefull to sand through the Gel coat?
The hull seemed very sound but had had one small repair to a knock just above the water line. It was obviously done with fibre glass but again no effort to rub it down smooth.
Question 2.
What would need to be done to put this right?
Finally. Anti fouling.
Lots of antifouling below the water line. Looked clean but also looked over dry and cracked.
Final Questions
Is Anti fouling slapped on a boat abit like underseal on a car.. it can hide anything?
Can anti fouling be easily stripped off?
If a boat has been out of the water will the anti fouling still work. (I seem to remeber that you should put a boat in the water within a certain time after applying the anti fouling)
Thank you to all, in advance.
Jim
Question(s) one.
Question 2.
Final Questions
Jim
