webcraft
The bit I understood was the bit about building a plywood box.
- W
- W
No you've got that wrong, plywood is out these days, it's aluminium plates and threaded rods for compression. Keep up ?The bit I understood was the bit about building a plywood box.
- W
So basically you have to monitor your app to make sure the BMS is doing what it should do?The BMS has an app, you can watch what's happening in real time. Individual cell voltages, pack net current in/out, temperature.
I'm not sure how else you would do it? It's not as if I have to actually do anything, I just check out occasionally, mostly for its function as a battery monitor.So basically you have to monitor your app to make sure the BMS is doing what it should do?
Sorry I'm not criticising just working out the difference between having to rely on the BMS to disconnect if the batteries cells are <> there setting or having cells monitor like these guys are fitting which is more reliable.I'm not sure how else you would do it? It's not as if I have to actually do anything, I just check out occasionally, mostly for its function as a battery monitor.
Again not arguing just point a few things out .tbh cell monitoring is a rather rough way of dealing with lifepo4 (again imho)
cheers
V.
not arguing either Vic, writing them down hoping for new ideas/experiences that would help me improve on thatAgain not arguing just point a few things out .
Cell monitoring is basically what the bms is doing.
Going back to my own set up , there no way if I left my batteries unattended for any reasonable time for any damage to happen unless there a short between cells,
in which the bms isn't going to stop.
And only brakers or inclined fuse is going to stop damage further down the line.
Bms just keep set parameters in line and in some of the once people are using here deturment how much current ,
Mine doesn't it's my breaker that does that.
Thinking about it my BMS is more like my second defend me bing the first.
In my set up ,not arguing either Vic, writing them down hoping for new ideas/experiences that would help me improve on that
fe, leaving the boat and having a leak or freshwater hose rupture meaning the freshwater pump will run indefinitely for say X hours (or overnight...) at say 10A, could cause a problem with already empty batteries..
mptt/b2b wont be able to help in this case!
and AFAIK the balancer board wont be able to drive a contactor to disconnect the lifepo4. So how is such a situation managed with their setup?
in my understanding their setup works for high voltage disconnect only
V.
I disconnect the panels and isolate the lithium battery if leaving the boat for a few days. You never know how long you will be away for...
The BMS themselves like yours are connected to the batteries , so no the BMS are not disconnected but the breaker which everything goes through is disconnected ,I don't have anything bypassing the BMS as Vic does and I never disconnect the BMS. I have a storage setting on my SmartSolar MPPT of 13.3 volts for both absorption and float. It can stay on that for a weekend or a year if needs be.
The bilge pump as I explained is bypass the breaker and is connected onto the batteries with an inline fuse .
The LED on the module use very little , I sure at one time you give a figure.
Personally I'm happer shutting everything down if I'm away from the boat , alway have done even when I use LA batteries ,
Should you have a short some where,
I fire is easily had.
Would you not normally turn off the master switch ? I sure you do ,
So really what you saying is you leave your panels connect at a low Float charge ?
Why? Lithium don't need it as they don't lost .
annoying having to search down the pages for this thread to post something new every week or twomaybe should ask for it to become a sticky...
anyway, testing bms with 3S2P 18650cells ? massive amounts of power running a 0.7A e/r light I have here on my desk @12V
things are ok. However I have an odd Q:
BMS can issue warnings and errors, fine.
One warning is cell imbalance, also fine.
Problem is how do you define imbalance?
in diyBMS the easy and fast solution is to check if any cell is passive balancing, and if so, issue the warning. However that means that once charging and reaching the top (especially on shorepower or generator) inevitably there will be cells balancing, but not being imbalanced to one another.
If I got that right, wouldn't it make better sense to issue the warning when indeed cells are imbalanced (as they may most likely be when emptying!)?
Assuming the above make sense, the big Q is: on prismatic LifePO4 cells, what value would be the one to set for an imbalance warning, and what for imbalance error ???
warning is just that, error means some action: throttle charging if it happens during charging, or turn off loads if happening on an empty bank.
what do the ones that have studied all that have to say? any ideas?
btw that's the datalog of the last 24h with a 3h discharging session last evening, followed by an overnight slow charging at 12.5V which from 8:00am started balancing (as can be seen by the cell temps and the PWM balancing algorithm data at the bottom). Stopped charging just after 10am and started a second session of discharging, half way through it realised that one of the two cells in bank three wasn't making contact to this stupid holder, so at 12:00 you see a jump in voltage and system is going strong will probably be 6h before a cell drops to 3V.
cheers
V.
any ref to that to study Poey? and is that whilst balancing or whist discharging? guess the latter!A common figure for maximum allowable voltage difference between cells - 'delta voltage' is 0.3 volts. Some BMS's do a disconnect at that setting.
cheers, I'll try to implement it in diyBMs and see how it goes (in testing... cells to arrive late Jan )It's just a figure that seems to keep cropping up. I assume it applies on both charging and discharging although more likely to show up on charging as the separate cell charging curves diverge at the knee.
