gregcope
not bad I guess, don't remember what the other guy doing tests found on his bus bars...
Greg, putting 4 and another 4 on their side, does the connector from one bank to the other needs to be longer on Ami's cells? wondering what lengths I should be ordering, 7 identical, or 6 + 1 longer?
I'm talking about fitting them as in this pic:
https://ae01.alicdn.com/kf/H18a2a70...les-Clips-de-Contacts-barres-de-connexion.jpg
For the ones that are "long side to long side" the 71.5+/-4mm ones fit. The71.5mm refers to the centre of the the bolt holes/studs. You will need six of these.
I cannot split my pack presently as its taped up doing a charge/discharge test.
However measuring from "short end to short end" is 25+/-1mm from centre of stud to side. So assume that two cells side by side the studs centres would be 50+/-2mm apart. The 71.5 ones will not fit.
For the "end to end" ones I would get the 50.5+/-4mm ones. You would need one of these. The pricing includes shipping to UK or Greece and it only took a week so bar the cost of one bus bar the risk is low if I have that wrong. Will buy you a beer if we meet to compensate if so!
Their cells look different in that the terminals are nearer the middle and have a larger gap to the shorter edge, hence why they spec 84mm ones for the cross over bar.
If you mean Ray as "the other guy" he found similar to the 2mm ones. We both have the same Internal Resistance tester (YR1035+). These ones should give an even better IR / connection compared to his.
