gwalarnyacht
Hi everyone,
I’m a beginner with DIY solar setups and could use some advice. I recently bought a 150Ah LiFePO4 12V battery from a vendor in China, but it’s been giving me issues. After some sudden voltage drops, it no longer provides enough power to my small sailboat.
When I opened up the battery, I found 24 cells at 3.2V, 25Ah each, arranged in a mix of series and parallel connections (see attached pic). The BMS is labeled “ShenGu Technology Co., Ltd., DMO-JL-0002-4S 4-series lithium iron, 200A, DM020190624001,” but I can’t find any information about it online.
Here’s what I’ve tried so far:
• Checked voltage before the BMS: 13.3V
• Checked voltage after the BMS: 3.2V
• Ran my 12V fridge directly from the battery terminals (bypassing the BMS) for two days without problems; voltage dropped only to 13.0V.
My questions:
1. Is it likely that the BMS is faulty?
2. Can I test the BMS somehow to confirm this?
3. If I need to replace it, what type/specs should I look for in a new BMS for this battery setup?
Thanks in advance for any advice or tips!
My questions:
