gregcope
Be
Sounds like the have high voltage disconnect sorted with MPPT and B2B (if they have a lithium profile) as long as these are the only charge sources.
You could choose to not use a BMS however what happens at low voltage? I recently killed a very old FLA because the Victron battery monitor was happily flashing/buzzing away with no one to hear it for a week or two it killed the battery. You need to be very careful of any small loads.
As @Kelpie points out a BMS need not be expensive and is there to protect some very expensive cells.
Being away from the boat at the moment I been interested in emails I had from several cruisers who are changing to lithium .
All four are cruisers we known for some years and at less 3 out of the 4 are quite knowledgeable when it comes to 12v and batteries.
There are all fitting 12v set up 400ah to 560ah
Here the interesting part ,
They plain not to use a BMS , instead use their victron mppt and b2b to monitor hight and low voltage,
Use cell monitors to keep an eye what each cells doing .
Connect the cells to a active balance board .
Considering the cost of BMS this could be a cheap way forward .
What's the view ?
