Poey50
if my XT 170 doesn't fit I'll do you a swap ??
I have also pulled the trigger on my cells, at long last.
Went with Shenzen Basen on Alibaba. £350 for four 280Ah cells including delivery. I don't know what will be added to that price on arrival, possibly UK VAT, but even so the resulting £420 is still much cheaper than buying the equivalent capacity deep cycle lead acid.
I haven't purchased my BMS yet. I considered Daly, mostly on the basis of Will Prowse's reviews, but there were also a lot of negative comments around, and I thought that the balancing current and low voltage disconnect were pretty lousy. For similar money the JBD/Overkill offers an apparently much better out-of-the-box solution, with double the balancing current and a more realistic LVD. And it appears to be totally configurable.
My broad system design remains the same- a second totally separate parallel installation, not connected to my boat's existing 12v. It will charge only from the new solar panels, plus the option of B2B charging if that proves necessary. And it will power new systems that I have yet to install, e.g. fridge, inverter. I will transfer the cabin lighting across to it, but critical nav equipment and autopilot will remain on the old lead-acids, as will the engine.
I swithered about how to tie in the inverter. The simple but brute force option was to buy a massive 300A BMS, but I didn't really like the idea of running all that current through the FETs for long periods. I am hoping that whatever inverter I end up buying will be capable of remote switching at low current, and if that isn't possible I will investigate using the BMS to trip a relay on the AC side. Worst case scenario is to use a big 300A SSR, but this should still work out cheaper and more reliable than buying a 300A BMS.
It's looking like the total battery cost will be about £600 for 280Ah. Compare that with a set of Trojans, £690 for 225Ah usable. Lifespan should be at least three times as many cycles, with much better charge acceptance and charging efficiency.
I will update the forum in two months time when the cells will hopefully be here...
so it's 690 quid for 4X6V T105 up there, right?It's looking like the total battery cost will be about £600 for 280Ah. Compare that with a set of Trojans, £690 for 225Ah usable. Lifespan should be at least three times as many cycles, with much better charge acceptance and charging efficiency.
very much interested to follow this bit, especially the VenusOs integration!im going to be using a REC ABMS connected to a Victron Cerbro GX to control the inverter and MPPT and fingers crossed a wakespeed WS500 to control alternator output all connected via CAN bus
He going to have to add on extra stuff on that like the BMS and some way to charge them from his alternator like a B2Bso it's 690 quid for 4X6V T105 up there, right?
If I had the room I think I might had gone for 4 more cells and had a 12v and a 24V bank for the larger loads ,Vic, sorry I'm 24V so 8S configuration. Not decided on BMS, but for sure it's going to have to integrate with Victron stuff very tightly, hence my interest!
V.
Why did you not use the Daly BMS with separate ports
or charing and discharging?
Then there cables , relay , fuses all the stuff people over look
But in the end he have a good batteries bank
Personally I think the attitude towards lithium may change. When cells were the biggest cost, you would do everything possible to protect them. The cells are now substantially cheaper per Ah than 6v deep cycle lead acid. So they only have to last four or five years to be a better buy. It becomes a bit harder to justify £1k+ on top of the line MPPTs etc with the aim of protecting the cells from any conceivable damage.
Taking for myself , I know very little about lithium probably not much more then most here if we don't include Chris who bern using them for some years .
I spend 8 weeks reading everything I could and watching YouTube.
Mine cells alone cost me 1400 , I did try and order them from China but after my order was taken and I paid for them, I got told I'm in a remote country and they couldn't deliver, so I ended up buy from Gremany around 400 euros more but hey thats life.
Personally I moved onto lithium because A I was very disappointed with my Trojan and B I wanted to start using less of my Gen which mean I needed something that would except large loads .
To be honest if all I wanted out of batteries was to draw nav equipment and light fridge I would had gone back to cheap LA .
As I speak the hob on and so it the hot water heater 2500w being used and the cells are at 3..32 v batteries 13 .3v soc 84% by morning we be down to around 65% we would had used 250ah out of our 370 we be back upto 95% by around 1300 then next day .
Am I working then hard , yes I am I not spent over 2k to hardly use them so they last 5000 cycle, if I get 2000 out of them I be more then happy and by that time lithium be much cheaper .
Couple of things I done which others may not agree with , I connect the shore charger to the b2b , I won't get as much charging Amps but I don't have to worry about the shore charger playing up and killing the cells.
I also only charging the cells to 13.8v , where most are saying they charge to 14.2 14.4 v
I don't feel I need to push the charging rate any higher , as my panels are doing a good enough job to charge them up to 95% leaving me part of the afternoon to draw high load for say the water heater
For this first build i'm following Will Prowse' specs and the guy from Freely roaming on YT & copying both as i dont fully understand everything yet.Why did you not use the Daly BMS with separate ports f
I don't understand why people are afraid of Mosfet switches. All house solar installation use mosfets. The BMS components were developed for solar installations. The semiconductors for balancing ,voltage measuring are all made by the big semiconductor companies.
I have on the roof 10kw solar and a 6000ah battery which gets charged and discharged almost every day and it works without any Relais. Perhaps we should look at the big boys for BMS and not for the self developed ones. They usually depend on one person.
I'm not sure any of us understand every thing yet,For this first build i'm following Will Prowse' specs and the guy from Freely roaming on YT & copying both as i dont fully understand everything yet.
