Aside. My generation as a young kid used to throw sections of asbestos cement garage roofs onto bonfires just for the bang .
Yes Split charge Diode- Is your boat a Vancouver by the way? - I had a similar one fitted to mine.
I had the exact same unit, then somehow managed to blast it by starting the engine without turning the starter battery switch on, which sent a lot of amps through it! I replaced with a Victron Argo Fet which is a more sophisticated version of the same thing and that has served me well for several years now. Victron Energy 2 Battery Argo FET Split Charger 100AYes I purchased her last November. A 274..model.
Had some good short weekend trips in summer .Now on the hard to get some winter jollies done. When you say had did you replace with something like a VSR ?
Seems odd to have retained that cross-link on the switches with a split diode?
Yes, they are wired to act in the same way as a 1-2-both switch. When split charging is added it is normally arranged so that start battery is isolated when engine is not running and you just draw from house battery. The split charge then takes care of alternator charging both batteries when engine is running. I would suggest removing link.From what I can see it appears to be wired so either the start battery or house bank or both are feeding everything depending on isolation switch positions , like the rotary type make before break switch. All the wiring diagrams I have looked at show the two yellow charging wires connected to the other side of each isolator ( disconnected from battery when switch is open ) . Does this make any difference?
Yes I replaced it and the battery switches with a BEP moduleYes I purchased her last November. A 274..model.
