Wiring steaming light
Halo
10 Nov 2009
Wetherby
I am replacing my combined steaming and deck light with a led one. There are three wires. Yellow,Brown and white. I assume one of them is a common negative. Any one know which one?
PaulRainbow
16 May 2016
Suffolk
The Osculati one is : Yellow wire is the masthead light (steaming Light), the brown wire is the foredeck light, and the white wire is the negative.
thinwater
12 Dec 2013
Deale, MD, USA
sail-delmarva.blogspot.com
Interesting color choice. EU/IEC 12 V L- is gray. US trailer wiring uses white for 12 L- ground, which is also weird.
Comments please. Are these generally correct?^^ I've seen some variations.
Stuff from China can be any of these, depending on where they think it is going.
Refueler
13 Sep 2008
Far away from hooray henrys
I brought to Latvia my old trailer board ..... wired up to use the standard multi pin trailer socket for UK cars. It was a pre-wired shop item - so not my work.
It did not work here with a shop wired socket in Latvia. I was getting daft things like Indicator light come on instead of brake light .. various mixed up and some just not working. Took ages to sort out ...
There was me thinking that this should be pretty well universal ... silly me !
Refueler
13 Sep 2008
As to wiring ... OK - the OP's question is answered and hopefully solved ....
When I have such - I get a battery and connect wires ... as I identify each - I stick a bit of tape on and write + / - / GND as found on the tape. If the light can be disassembled .. GND wire is usually quite evident.
TSB240
17 Feb 2010
I installed one of these.
The decklight is very bright but whenever it is turned on the receive on my VHF is completely blocked by interference. Might be worth checking if you have the same problem.
I don't use cheap and nasty vhf coax and don't have a join anywhere between the mast head and the radios. I have tried ferrite rings with no significant impact on reception.
Refueler
13 Sep 2008
That is a known matter with some LED's ....
Ferrite rings and twisted pair wiring is only effective for wiring and not the LED itself.
Ammonite
7 Feb 2007
Thanks. I shall check next time I'm on the boat. My VHF is installed with what looks to be a very high spec circa 10mm diameter cable so it will be interesting to see if this makes any difference
thinwater
12 Dec 2013
Deale, MD, USA
The USCG lists nav lights, and to get a listing, they must be tested for VHF interference. A steaming light would be included. This is not part of the ISO standard? Non-USCG list lights are not permitted on US boats (although it happens a lot ... then the VHF does not work).
Halo
10 Nov 2009
Wetherby
Good point but tsb240 said it was the deck light that gave the problem. Probably meets the standard but skimped on the second function
salar
5 May 2009
Hampshire, UK
harley25refit.blogspot.co.uk
Marine LEDs are supposed to include circuitry to eliminate this, which is why cheap non-marine 12volt LEDs are not recommended for marine use even though they would work. I'm surprised an Osculati LED would cause interference, possibly worth getting a replacement if it's new enough?
Never Grumble
29 Sep 2019
England
With the Oscaliti does anyone know if this interferences happens when the navigation light part is lit. It is not often that I could envisage having the deck light on when I am using the VHF so could probably live with that causing interference.
rogerthebodger
3 Nov 2001
I had interference on my VHF from a PWM solar regulator.
I fitted some electrolytic caps across the regulator and the interference stopped.
The bigger the cap the better but must b at least 20 vdc and connected correctly
