Jassira
A while ago I brought a Nilsson Maxwell HWC3000 hydraulic windlass from the USA via ebay, and now I want to fit it.
The boat is a Bruce Roberts 53ft cutter, displacement in the region of 22tons. My existing ground tackle comprises a manual Simpson Lawrence Sea Tiger 555, 75lbs CQR and 100m of 11mm chain with a pitch of 29.5mm an external width of 36mm which I can't find referenced anywhere..
Needless to say the gypsy on the Nilsson and my chain don't match, so I'm left with 3 options
a) Get a new gypsy to fit my exiting chain
I have spoken to Nilsson in New Zealand, they are very helpful and knowledgeable and say they may be able to modify one of their standard gypsies if I send them an 11 link sample of my chain, but the chain came with the boat, I assume it's only grade 30 and I've always felt it's a touch to light.
b) Get a new chain to fit the Nilsson gypsy
The Nilsson gypsy seems to be for 10mm chain, I think 10mm grade 30 chain is to small for my boat, grade 40 could be an option and if I can source it, grade 70 may be a solution, anybody know of a supplier ?
c) Get both a new chain and gypsy
This may turn out to be my only option, if so I would be probably to go for a grade 40 12mm chain
At the risk of opening a can of worms I would value opinions on the chain size, but also wonder if it's possible to have the Nilsson gypsy modified in the UK.
Finally, before I do any of the above it would seem sensible to have the windlass serviced and checked over, can anybody recommend a firm that can do this, preferably in the south east.
many thanks in advance.
