Buck Turgidson
Poor upwind. Asymmetric performance. Can't heave to.What are their limitations?
poorish upwind but good enough unless racing
I’ve not noticed asymmetric performance but I don’t sail with my eyes glued to the GPS so I probably wouldn’t notice
Can heave to, so far anyway.
The thread is about cruising, and I’m fine with mine.
btw in coastal cruise go be noticed that many many yachts just motor upwind anyway.
The other thing I’ve remembered that junks should be marked down on, is that they look frightfully untidy. And in the yacht retail market that is a major factor.
NealB of this parish switched back.Very True, I can't feel any difference between tacks ether.
I guess only junk rig sailors which are usually ex Bermuda sailors get it.... Mind you don't know any junk riggers that switched to Bermudas...
Met a familly in the Algarve that sailed down in a Junk rigged boat from UK. He would never have one again.
I know the guy! He sails from my club. And he's been sleeping with my wife...Someone has changed their bradwell 18 to junk rig, I think he's a member here? I really like the idea.
No need for explanation. If you look at what people in this thread have said about junks, it's all about ease of reefing, low stress (both on the rig and the skipper!), simplicity, robustness etc. Nobody has said that they are faster than Bermudian. Having said that, a well set up modern junk will sail perfecty well; many of them at least as well as the equivalent Bermudian (excluding super-fast highly crewed racing machines). But if racing is your bag, I wouldn't normally suggest Junk.Can you explain ... why no one every won a race in a junk rig if they are so amazing?
I disagree; that isn't "the key" safety requirement. Important yes - and a modern junk will beat off a lee shore just as well as a Bermudian. But not "the key" requirement that supercedes all othersThe key safety requirement of any sailing rig is surely to be able to beat to windward to claw off a lee shore.
Junks got a reputation for being poor upwind back in the days of flat cut sails. That reputation is no longer deserved by modern junks with cambered sails.[limitations] Poor upwind. Asymmetric performance. Can't heave to.
Good to hear you have nothing against junks! It's certainly true that many junkies (myself included) have a certain missionary zeal. But I think you underestimate what would be needed to supplant the "industry standard" rig. First, remember that the western junk is a recent thing, and has only started being competetive (with cambered and split sails) in the last 10 to 20 years. A boat designed for Junk will be different from one designed for Bermudian (mast position different; scantlings in that area stronger; less strength needed in other areas; interior accommodation must allow for keel-stepped mast). And of course in the days of RCD there's a lot of expense to certify the new design. All of which means that there's a very large cost for a manufacturer to switch to offering Junk even as an option. Before any manufacturer did that, they would need to be very sure that there was a very strong market, which means that the Junk would have to beat the Bermudian in pretty well every respect, by quite a considerable margin, to justify the financial risk.And just to be clear, I have nothing against junk rigs. They are just massively over hyped by their beloved following despite their limitations. If they were all the things they are proclaimed to be they would be the industry standard by virtue of profit margin. They aren't!
Remember this is a home made rig, with a home made sail, and a mast that I made much heavier than it needed to be. It's the first time I'd ever made a mast or a sail.Base on information provided for Boat: Bradwell 18 Mk1... the handicap is 1159 ...
River Rat is expected to have a range of race performance returns dependent on crew number, course and wind strength, if the course is a Windward/Leeward style course rather than an Olympic or Random Circular style course then a lesser performance can be expected.
The upper quartile standard rig version of the Bradwell 18 with 150% genoa has a ByCN of 1153... without the class symmetrical spinnaker the handicap is 1186.
