Roberto
Last time I weighed anchor there was quite a chop and the boat was pitching heavily, as a result, the bow roller shaft has been bent.
The anchor was set very deep in the bottom (has brought up half a cubic metre of mud), I used all possible precautions with the windlass, shortening scope little by little (talking centimetres here) and waiting a lot of time in between to give the anchor plenty of time to break free, but up and down movement of the bow caused the chain to occasionally become bar taut, with the result above.
Should this happen again (should I say when), I would like to have a way of transferring the snatching loads from the bow roller to the side of the bow through this (not my boat, just took the first picture from the net)
Ideally, I would like to find a sort of metal device that could be fitted around the chain, and through which the chain can only move in one way, the metal device being tied to a rope going through the fairlead, to a cleat.
That is: I retrieve the chain with the windlass (chain on the bow roller), the metal device slips freely down the chain, when the chain is sufficiently taut I release a little from the windlass, the metal device grips and stops the chain from falling back down again, all the hard job is done by the rope through the fairlead leaving the bow roller shaft alone. Then again a little more with the windlass, and so on.
I thought about a one-way chain stopper like this, though I only used them when bolted to the deck, do you reckon if might be used after attaching it to a rope of course; would it slip down on an almost vertical chain?
fwiw boat 12m, 10mm chain, no way to do anything by hand in this type of situation
thanks
thanks
