machurley22
Apologies if this has all been covered before but the search facility is acting the goat.
My water tank is a pointy one up for'ard and is formed as part of the interior moulding with a separate screwed-down, reinforced, triangular GRP sheet as the top surface. This has always leaked a little and you can hear air being drawn in when water is pumped out. This is presumably because the tank has no vent which I presume it should. The filler pipe has a horizontal section in it's run (just below deck level) through the chain locker and I'd planned to make a small hole in the top of the pipe here to allow air in. A small amount of water may escape when filling but this would drain into the bilge. What do you think?
What should I use to re-seal the tank lid? It currently uses a grey non-setting goo a bit like soft blu-tack. I'd thought of using some thin self-adhesive neoprene tape. The mating surface is about half an inch wide. Any recommendations would be gratefully received.
Dave
<hr width=100% size=1>The question 'Why not?' is a very difficult question to answer, and a very foolish question to ask.
Dave
