Overandunder
I've just replaced a Volvo shaft seal with the Radice type which has a greasing point and vent pipe take off moulded in.
Also installed is a Vetus syphon block mounted between the heat exchanger and exhaust elbow (Yanmar 3YM20). This is fitted high in the engine compartment (which equates to about 150-200mm above sea level in my case). The Vetus is the common type fitted with a spring loaded valve, on top of which is a spigot to take a length of narrow bore hose down to the bilge.
I'm aware the Radice doesn't require a forced water connection to the vent when fitted on a sail boat - however to have a constant flow of water over its cutless surface when motoring makes sense to me. So has anyone removed the valve from the Vetus to create that flow of water ? Would the syphon hose then require a T piece to allow air in ?
Any potential issue with doing this ? Of course it will somewhat reduce the volume of water ejected into the exhaust elbow - but is that significant ? The engine has a syphon break fitted in the bilge as well as a high loop before it exits on the starboard side. Appreciate any thoughts.
