Shuggy
Firstly, I am a spinnaker novice so be gentle!
We have a 1971 Nicholson 43 which we've had for just over 18 months now. This year we've flown the spinnaker about 15-20 times, mostly with just two adults on board (myself & my wife). We've taken it gently and have progressively got a bit bolder, albeit (before this weekend) with a self-imposed limit of 15 knots true wind. I should say that before June this year I'd never used a spinnaker on any kind of boat and bodged it all together using hints and tips from friends and from the internet.
The spinnaker pole is a telescopic Selden one, a previous owner having ditched the rather nice pair of classic ones at some point in the distant past. The trouble is that it bends like a banana under high load as we discovered in 20 knots of true at the weekend. I didn't get a decent shot of it but you can sort of see it in the attached image. The inboard end had slid down the mast track at this point, and we were just about to snuff it. The banana action is not helped by the fact that the downhaul is at a fixed point rather than on a bridle (is that the correct word?) because the pole is telescopic.
The Selden website does not recommend that the pole is used as a spinnaker pole at this level of extension so we clearly need to get something stiffer.
Firstly, I confess that I did not measure it but will do so soon. But in the meantime...
1. Does anyone have access to the dimensions of the 'factory fit' spinnaker poles for this type of boat, and...
2. Any tips on where I might pick up a second hand one of the appropriate length? I would prefer to get something period rather than a modern one. I'd go for a modern one as a last resort.
Thanks.
Thanks.
