Kukri
I seem to have an awful lot of varnish in my life.
This is probably because a single parent father and two teenage boys have between us:
1. A 26ft clinker gaff cutter
2. A 9ft glued ply clinker tender to (1.)
3. A Firefly (still varnished)
4. A cold moulded International Canoe.
After 40 years of messing about with wooden boats I am currently in favour of:
A. The fit and forget bits, eg spreaders, bowsprit, rails, which get hard wear and don't get looked at closely - Coelan. It will do ten years and is worth it. Be sure to get the application right, as it is eye wateringly expensive. Thin it and rub down between coats; don't just slop it on.
B. The bits that are small and fiddly and get clobbered a lot - wooden block shells, sliding seat and carriage of I.C. - Deks Olje. Use No 2 over no.1.
C. Bits that may get a boiling kettle stood on them i.e. the saloon table - Crystal for teak 2 pot. Obliged to Annie Hill for that one. Being a two pot varnish one pair of tins will last for many years.
D. Everything else - Epifanes, regular, and you really need eight coats. Thin the first four. Use Owatrol in the last four.
