rotrax
"To determine if your wiring has been affected by moisture, cut off the terminal on a suspicious wire and strip back about a half-inch of insulation. If the wire is black, and not shiny pink, then corrosion has begun to migrate along the conductor. You’ll need to strip back the wiring until you find clean, pink copper. Usually this requires stripping back no more than an inch or so of insulation. Snip off the corroded wire and install a new terminal as described above."
On the occasions I've had to deal with blackened wire on boats around 40 years old, I've given up at around a foot and replaced the whole length
Seen the black oxidation four feet up the wire. Same on old cars too.
