prv
You may remember a while back I asked about cylinder head bolts for a 4hp 2-stroke Johnson twin. Well, I put it back together without any trouble, and it seemed to run ok. However, it turned out to only work in neutral - as soon as I put it in gear, it would die. Or rather, five seconds or so after putting it in gear, it didn't die instantly.
Google suggests there are various possible causes, but having had the head off, my natural worry is that I damaged the seal while removing the old gasket. So I decided to splash out fourteen quid on a compression tester: http://www.ebay.co.uk/itm/290949832664 to find out. On Sunday I finally got round to trying it. I had the set assembled according to the instructions, and the adaptor firmly screwed into the spark plug hole. But when I pulled the cord, the gauge showed nothing whatsoever. Not a flicker. On either cylinder.
I'm puzzled; the only explanation I can think of is that the gauge is faulty. There can't be zero compression in the engine, otherwise it surely wouldn't have run at all. But I am of the generation for which even crappy old cars were fairly reliable, so my experience and skill with engines is limited, and I turn it over to the forum for thoughts.
