prv
Have you tried turning it over with a finger over a spark plug hole?: you should definitely feel the pressure (but it won't hurt).
I haven't; I'll give that a go.
It sounds as though your compression gauge is faulty. Can you try it in the car? or lawn mower
Drop test =
Short out or disconnect one plug at a time. If one is not firing disconnecting it wont make any difference. You should get an equal effect from both. Take care Use insulated pliers or you'll get one hell of a shock!
I assume youve tried new plugs already.
If ignition is all OK turn your attention to the carb and clean thoroughly. It's possible that the high speed jet is blocked.
CDI ignition system still have coils.
Thanks - I may give that a go. Leads can shock even through the rubber, then?
Always worth changing the plugs.At first I thought I had, because I remember buying them (I'm working on this engine in dribs and drabs when I have time). But when I took them out to do the compression test, they were the old ones - I realise now that the replacements I bought were for spares!
Always advised on the American outboard forumsIn general I haven't done much in the way of troubleshooting - testing the compression was to be my first approach because if it turned out that I'd knackered the head with excessive use of wet&dry to remove the remains of the old gasket, there'd be no point trying other things. The compression test seemed a nice positive yes-or-no answer.
You might have to clean it again more thoroughly. ( BTW I now realise that there is a only a slow running adjustment on that engine) The diagram shows a funny little bladder thing. That is a very basic fuel pump Is that OK I'm abit puzzled by the fact that it does not die for 5 seconds or so........ makes me wonder about fuel flow although a problem there would not cause it to die even that soonAlready given the carb a good clean when I had the whole engine in bits. I didn't deliberately disturb or adjust anything.
So, I think my next step is to try the compression tester on the generator and confirm that it's knackered. Then get my hands on one that works. Then if that shows ok, start looking at other possible causes.
I hesitate to ask this and apologize for doing so, but your compression tester hasn't got a pressure release valve that you have forgotten to close has it?
I can't quite remember, but I think the fuel pump is only involved when using a remote tank.
It is also driven by vacuum pulses from the crankcase via a hose.
Good thought.At a guess, crankcase reed valve - it happened to me on Johnson 9.9 twin, in 1982. Had to spend the night anchored just by #16 channel buoy, just out of the channel near Brownsea.
Exactly the same symptoms!!
Good thought.
I'm not into Johnsons, didn't realise they were reed valve.
Not usually something that's troublesome as far as i can make out but here they are #4 ( only one of two shown. ) between the inlet manifold #1 and the crank case
